Simple Question about a b18b stock
Well balanced Crank , rods, and pistons. Thats what i see for most LS builds. Are you planning on doing an LS/VTEC? If you did those things to the block, youd be just about set to put a VTEC head on there.
balanced rotating assembly
arp rod bolts or forged rods and pistons
stiffer valve springs
port work to help the crappy head breath better
cams that make power higher than 7000rpm
tune
tune
