Brights stay on and fuel pump won't prime.
Old Jun 23, 2007 | 11:15 AM
FrOsTwHiTeDC4's Avatar
Default Brights stay on and fuel pump won't prime.
I pulled my dash the other day to run nitrous lines and when i put it back in everytime i connect my negative side of the battery cable the brights will stay on and i can't hear the fuel pump prime. I've checked the main relay, fuses, switch for the lights. Anyone have any ideas on what it might be?
Old Jul 6, 2007 | 09:12 AM
GSR-TRBO-DA's Avatar
Default Re: Brights stay on and fuel pump won't prime. (FrOsTwHiTeDC4)
dude my pump does not prime also i don't know if my brights stay on i haven't checked but i will. what have you checked? i replaced main relay and pump and it still doesn't prime. i'm going to do more searching and see what i can come up with. i think you and i have the same problem. did this just start happening or it happened when you put a swap in your car? because my car ran fine with no problem now the fuel pump doesn't prime when i go to start it after i pulled my swap i am going to work on it all day so we will see.
Old Jul 6, 2007 | 01:36 PM
i found out that the problem was my ecu i don't know what happened but i did read abput static electricity can cause a ecu to fry!!
Old Jul 7, 2007 | 06:28 PM
Default Re: Brights stay on and fuel pump won't prime. (GSR-TRBO-DA)
dude i am back it ran good for a little bit then couple hours went to start it again nothing my LIGHTS DO STAY ON don't know what it could be my gas gauge doesn't work also fuel pump still doesn't prime .hit me back if you know anything
wwolf771177
Mar 25, 2013 02:54 PM
93b20z
Aug 2, 2010 05:15 PM
tempname
Sep 7, 2008 05:46 PM
92DXinMIAMI
Jun 8, 2005 06:43 PM
rwcdrums
Jun 19, 2002 06:15 PM
