Battery Dieing..?
Old Jun 23, 2007 | 10:25 AM
Huntley2147's Avatar
Default Battery Dieing..?
If i leave my car sit for like 10+ hrs the batt dies... and then when i put on the jumper cables the neg side of the batter sparks... do i need a new batt or do i need to get a better ground..?
Old Jun 23, 2007 | 10:29 AM
Johnny-Red's Avatar
Default Re: Battery Dieing..? (Huntley2147)
Youve got a drain somewhere if you have a sound system check that somethings stealing juice if the negs sparking
Check everything before you end having to buy to something
Old Jun 23, 2007 | 10:44 AM
DenzComp's Avatar
Something is definitely drawing power.
Old Jun 23, 2007 | 10:53 AM
thanks.. but i turened off my deck and its still happening.. i know its not my alternator because when im driving its running at 14v
Old Jun 23, 2007 | 10:54 AM
DenzComp's Avatar
Pull the fuse for the radio and see if it still does it.
Old Jun 23, 2007 | 10:59 AM
alright another thing tho when im driving and i put it in neutral the batt volts fall to like 12v then soon as i put it in gear and give it some gas it goes back up to 14v
Old Jun 23, 2007 | 12:01 PM
why would my neg side of my batt be sparting... any ideas?
Old Jun 23, 2007 | 12:41 PM
janz3n's Avatar
Default Re: (Huntley2147)
are you moving the jumper cables one the terminals? or it just sparks when you leave them on and dont touch them?
Old Jun 23, 2007 | 12:42 PM
when i put on the neg one it sparks.... and the pos doesnt spark
Old Jun 25, 2007 | 02:39 PM
Johnny-Red's Avatar
Something drawing power, check to make sure your interior lights arent on, yeah stupid but its usually stupid crap that gets ya.
Start yankin fuses 1 by 1 and find what stuck on.
Old Jun 25, 2007 | 02:52 PM
CEMAYHALL's Avatar
Do you have an alarm? If yes, unplug the brain to the alarm!!! Alarm Brains are known to drain power when going bad...
Old Jun 25, 2007 | 04:33 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huntley2147 &raquo;</TD></TR><TR><TD CLASS="quote">alright another thing tho when im driving and i put it in neutral the batt volts fall to like 12v then soon as i put it in gear and give it some gas it goes back up to 14v</TD></TR></TABLE>
There is the start of your problems, The car should idel 13.75 to 14.5 volts. It should be on the 14 volt sides. I would go have the alternaotor tested. Then have a voltage draw test on the car.
Old Jun 25, 2007 | 10:34 PM
so i put in a new batt and my battery light came on.. then when i was on the high way i got on it and my bad volt went up to 15.7..... i dont think this is normal.. lol
Also.. i have no more low beams from when i had the other batt in and i was driving then they just shut off and i had to use my high beams..
Old Jun 26, 2007 | 01:32 AM
Well since you have a bad regulator in your car. You provided a nice voltage spike. This in turned blew the fuse to your headlights. I would not drive the car to you fix the alternator. Better be luck that its not the ecu. Word of advice fix it soon or your battery is going to overheat and explode.
Old Jun 26, 2007 | 08:12 AM
cb07's Avatar
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">Word of advice fix it soon or your battery is going to overheat and explode.</TD></TR></TABLE>
Thats a pretty good way of putting it.
Old Jun 26, 2007 | 02:26 PM
yea... untill my next check im going to just leave my lights on and other things while im driving to keep my voltage at 13-14.. it worked today
GPC91
May 7, 2013 09:06 PM
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
wood181
Apr 15, 2008 06:59 PM
reAper86
May 5, 2006 02:51 PM
axcxe
Nov 5, 2003 06:43 AM
