need help no power to ecu and fuel pump
its a 92 eg si with a 05 k20z1 swap (motor, tranny, wireing harness) Im useing kpro with the hondata jumper harness and the chameleon harness. I did everything the instructions told me to on the harness. The fuel pump is'nt priming and the ecu is'nt getting power. When we plug in the kpro to the car and laptop it said I was online but the ing was off but the key was on, lights on the dash work and the car turns over. I put the kpro in my friends eg and it worked fine it said the ing was on it powered up the fuel pump, so we put my map on and disabeled the immobilizer then put it in my car and nothing. I checked all my fuses and the have power the main relay has power but nothing at the pump. I have 3 grounds and moved the ground to the valve cover like I was told, also I have error's for evap, a/c and egr not sure if that has anything to do with it but I thought I'd through it in. I searched for like 2 hours can't find anyone having this problem, most people have one or the other not both.
hatchet_honda
Aug 7, 2011 10:48 PM
Naudlee
12
Nov 25, 2008 11:27 AM
