Street Legal Turbo for Prelude SH?
Old Jun 23, 2007 | 08:20 AM
kelvinchau125's Avatar
Default Street Legal Turbo for Prelude SH?
What street legal Turbo kits are there for the Prelude SH? I know theres the Greddy Kit. Any others?
Old Jun 23, 2007 | 08:26 AM
96vtecI4's Avatar
turbonetics
Old Jun 23, 2007 | 09:03 AM
shrirag's Avatar
Default Re: Street Legal Turbo for Prelude SH? (kelvinchau25)
you know if you turbo an SH, there is a good chance you will no longer have ATTS. It disables at 250whp. Please research about turbos before just slapping one on. SH's aren't really made to be upgraded too much besides bolt ons. You're gonna have to do an OBD2 --> OBD1 and drop the ATTS.
Old Jun 23, 2007 | 10:11 AM
Default Re: Street Legal Turbo for Prelude SH? (shrirag)
Oh, I'm only looking for about a 7psi boost which'll bring me to about 235ish WHP. I'm looking to keep street legal because I've been rolled three times in the past six months and had my hood popped. I got away every time because everything I have is legal. I'd rather not have to deal with remove and install.
Yeah, not looking for any serious horse power. Just enough to give STi's some trouble.
Old Jun 23, 2007 | 10:29 AM
Where can I find this CARB Exempt Turbo kit made by Turbonetics? Can anyone provide a link? I looked on their website and found nothing about CARB Exempt turbos.
Old Jun 23, 2007 | 12:50 PM
shrirag's Avatar
I can't really help you with finding it, but do you have stock internals? I mean you can probably run the turbo, but you have a higher chance of killing your engine. You might wanna sleeve the block and throw lower compression pistons. There are many stories of people leaving stock compression and losing the life of their engine, while others have no problems. Honestly even with 235 whp you will not keep up with an STi.
Old Jun 23, 2007 | 01:55 PM
=/ Yeah, I was thinking of getting the lower compression pistons. And to top it off, it's even worse for my engine considering I have the H22 Type-S with a whoppnig 11.5:1 compression ratio. PERFECT for boosting. I thought it'd be a bad idea for my engine.
Should I just go N/A and go full Skunk? That way the dollars I spent upgrading to a Type-S won't die in vain? I thought it'd be a waste to just swap out those Type-S pistons.
And I think 235whp for a Prelude would be well more than enough to spank some STi's. STi's are at about 220whp because of their AWD drive train. They'd probably get us Preludes on the launch but at 3400 lbs, I'd have my money on the Lude, don't you think? I mean, I've beaten a regular WRX with my Type-S on the drag strip before.
Old Jun 23, 2007 | 01:58 PM
xxmastermindxx's Avatar
could've sworn STI's are at just under 300hp AWD, not reduced because of it's drivetrain. a normal WRX is at about 220hp AWD.
Old Jun 23, 2007 | 02:06 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelvinchau25 &raquo;</TD></TR><TR><TD CLASS="quote">I have the H22 Type-S with a whoppnig 11.5:1 compression ratio.PERFECT for boosting.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelvinchau25 &raquo;</TD></TR><TR><TD CLASS="quote">I thought it'd be a bad idea for my engine.</TD></TR></TABLE>
u think!!!
Old Jun 23, 2007 | 02:32 PM
shrirag's Avatar
Doing all motor is not easy, and won't push you too far beyond 210-215 whp. And that'll require quite a bit of money. With type S pistons no way you should turbo. I don't know what STi's push to the wheels, but 220whp sounds way too low for me. But back to the point, your only option really is NA, and adding a few things such as customs headers, intakes with BPi, exhaust, TBs, and a nice tune. I say just do a few more bolt-ons and you are set man, but trying to get to 230 whp on NA is not going to happen and your turbo idea won't work with type S pistons. Sorry.
Old Jun 23, 2007 | 02:36 PM
Default Re: Street Legal Turbo for Prelude SH? (DfwBB6)
Yeah, there was a lot of sarcasm in my last response. I should've noted that. But yeah, to my knowledge, the STi is 300hp at the flywheel, not at the wheels.
WRX 3500lbs 220chp
Type-S 3100lbs 220chp
WRX + Prelude Type-S = Good Race
STi 3500lbs 300chp
Type-S + 7psi 3100lbs 300chp (Modest Approximation)
STi + Prelude Type-S+7psi = Good Race
*Chp = Crank Horse Power
Old Jun 23, 2007 | 02:55 PM
Yeah, the Type-S is supposed to be 220chp which is approximately 190whp. 180whp w/ ATTS which is what I have. ATTS begins to have trouble @ 250whp, which is my ceiling. So seeing as the Prelude Type-S w/ATTS has a 20% loss to the wheels, 300chp should bring me to about 245ish at the wheels. Someone correct me if I'm wrong.
Old Jun 23, 2007 | 03:33 PM
shrirag's Avatar
do you just have type S pistons though? I don't think they will give you another 20 hp honestly. Type S engines also have Type S cams which, which add a few hp as well. S i mean you might be around 210-215hp, which is probably around 170-180 whp. But I still recommend getting sleeves man with lower compression, your car might run for a little while, but it won't last anymore like a Honda should. I don't know anyone with that sort of compression with a turbo, it usually isn't a good combo.
Old Jun 23, 2007 | 04:16 PM
5hif7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrirag &raquo;</TD></TR><TR><TD CLASS="quote">It disables at 250whp. </TD></TR></TABLE>
It doesn't really "disable". Your car is just making more power than the unit is capable of handling and thus the ATTS becomes 81 lbs. of dead weight.
Also, I've seen plenty of people run that modest (7 psi) amount of boost on a stock motor. True many blew after a few months, even weeks, but a few have lasted years with proper knowledge, but as always, <U>it's about tuning.</U>
Old Jun 23, 2007 | 04:23 PM
matix's Avatar
Default Re: Street Legal Turbo for Prelude SH? (5hif7)
I own a STi with turbo back exhaust and a protune. I put down 311 whp 320 torque. Most STi's arnt stock and have bolt ons like me. Keep in mind a good driver will hit 1.6 to 1.7 60' times.Good luck!
Old Jun 23, 2007 | 04:35 PM
Default Re: Street Legal Turbo for Prelude SH? (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">I own a STi with turbo back exhaust and a protune. I put down 311 whp 320 torque. Most STi's arnt stock and have bolt ons like me. Keep in mind a good driver will hit 1.6 to 1.7 60' times.Good luck! </TD></TR></TABLE>
yea thats what i figured bout STi's, ~300 whp stock, regular wrx is more like ~220 whp stock. on a side note, i saw a HOT chick driving a new WRX the other day, i mean driving the CRAP out of it, so hot, and another one that i see a lot, driving the crap out of an Evo MR, sexy girl and car
Old Jun 23, 2007 | 04:50 PM
Default Re: Street Legal Turbo for Prelude SH? (xxmastermindxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">
On a side note, i saw a HOT chick driving a new WRX the other day, i mean driving the CRAP out of it, so hot, and another one that i see a lot, driving the crap out of an Evo MR, sexy girl and car </TD></TR></TABLE>
Sweeeeeeeeet!!!
Old Jun 23, 2007 | 05:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrirag &raquo;</TD></TR><TR><TD CLASS="quote">do you just have type S pistons though? I don't think they will give you another 20 hp honestly. Type S engines also have Type S cams which, which add a few hp as well. S i mean you might be around 210-215hp, which is probably around 170-180 whp. But I still recommend getting sleeves man with lower compression, your car might run for a little while, but it won't last anymore like a Honda should. I don't know anyone with that sort of compression with a turbo, it usually isn't a good combo. </TD></TR></TABLE>
No, I actually have the entire Type-S motor. Which to my knowledge basically has higher compression pistons and more agressive cams. But yeah, I don't think I'll be boosting my H. Thanks for the advise.
Old Jun 23, 2007 | 06:42 PM
ProjectBB6's Avatar
Nice numbers... 60 foot times are nice too. However on the highway AWD no longer has an advantage. A prelude with the same ballpark figures is the faster car. Not trying to sound like a bench racer or anything but its true. Mainly contributed to the weight of the car.
Old Jun 23, 2007 | 06:55 PM
Hey what about the Jackson Racing Supercharger? Same harsh results as putting a turbo on the Prelude?
Old Jun 24, 2007 | 10:23 AM
shrirag's Avatar
You still need the same general basic setup. With JRSC you won't push as much, but it'll respond a lot better to street driving. But I still think you would have to drop compression to do so, sorry to say, I say just throw some bolt ons and call it a day with a type S engine.
Old Jun 24, 2007 | 03:26 PM
matix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
Nice numbers... 60 foot times are nice too. However on the highway AWD no longer has an advantage. A prelude with the same ballpark figures is the faster car. Not trying to sound like a bench racer or anything but its true. Mainly contributed to the weight of the car. </TD></TR></TABLE>
Def true I walked a wrx with my accord back in the day. If we went from a dig he would have got me. The accord(20xwhp) is still so fun to drive. You wont be dissappointed with a built n/a h22. If your set on boost throw some mahle pistons in there with some rods and call it a day.
Modified by matix at 7:37 PM 6/24/2007
kelvinchau125
Jun 20, 2007 10:59 AM
the_one_6682
Mar 21, 2006 11:29 AM
playboyillusion
Jul 3, 2004 02:52 PM
btrim23
Dec 31, 2003 04:47 AM
Merlin1068
Sep 23, 2002 08:51 AM
