DA 11.1 brake upgrade
Old Jun 23, 2007 | 08:13 AM
Red_ED8's Avatar
Default DA 11.1 brake upgrade
I have read that thread for the last 30 min but I am still not clear as to if you use the 25T caliper mount? When you are use the accord calipers with prelude rotors on DA knuckles do you need the 25T mount?
Old Jun 23, 2007 | 08:14 AM
Boosted Chemist's Avatar
Default Re: DA 11.1 brake upgrade (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">I have read that thread for the last 30 min but I am still not clear as to if you use the 25T caliper mount? When you are use the accord calipers with prelude rotors on DA knuckles do you need the 25T mount?</TD></TR></TABLE>
you can use the 25t or 23t, the 25t needs 3mm of machining, im not 100% sure but i think that is what i get from that thread
Old Jun 23, 2007 | 05:54 PM
Red_ED8's Avatar
Default Re: DA 11.1 brake upgrade (Boosted Chemist)
Thanks, just needed a second opinion.
Old Jun 24, 2007 | 08:53 PM
roastbeefrichie's Avatar
...on a 90-93 integra da front knuckles, to upgrade to 11" rotor set-up, you'll need:
*itr calipers, stamped 17cl15vn (can be found on older vigor, cl, tl, rl, legend, accord, cr-v, integra type-r, prelude, odyssey...i'm sure i missed a few), legend 2-piston calipers or nsx calipers
*23T, 25T or 28T brackets
*+97 prelude rotors
*new brake pads
because of rotor offset, you'll need to machine your brackets (23T, 25T, or 28T will all work) and remove aprox 2-3mm or 1/8 where the bracket mates with the knuckle. you'll also need to re-drill your rotors to 4x100 since there isn't an 11" rotor available with the correct offset. check the link below (although this is for a dx knuckle w/ 10.3" rotor), the premise for your 11" rotor set-up w/ a bigger caliper is the same:
https://honda-tech.com/zerothread?id=1484555
for 11" 4x100 rotors:
https://honda-tech.com/zerothread?id=1972552
pm brakeexpert, he machined my brackets & does great work
Modified by roastbeefrichie at 1:52 AM 6/25/2007
Old Jun 24, 2007 | 09:44 PM
shyxboy's Avatar
Default Re: DA 11.1 brake upgrade (roastbeefrichie)
sry to jump in to your post, had the same question but different setup... can anyone tell me if a 96+ civic dx front brakes work for a crx upgrade??
Old Jun 24, 2007 | 09:51 PM
Default Re: DA 11.1 brake upgrade (shyxboy)
88-00 dx...knuckles, calipers, pads, rotors all interchange
JDMHN8
Oct 21, 2004 04:25 PM
Missingsohc
Jul 18, 2004 03:28 PM
CD5 Sedan
Jun 20, 2003 02:38 PM
Westrock2000
Mar 29, 2002 07:01 AM
