stop the squeaking!!!!!!!!
Check all of your bushings, make sure the rubber is in good condition and not hardened like a rock or cracked and falling out. A lot of times the bump stops for the springs/struts will deteriorate and cause squeaking. If they all seem to be in good condition, you can try putting some silicon lubricant on them, either the spray or the actual stuff in a tube, but I would probably suggest spray just because it will get into all the small cracks easier.
I think its my trailing arm bushing because its kinda crack.
I guess i hit up the store to pick up some silicone lubrication spray.
When I do pick it up imma spray all over my bushing and the shock on my car.
thaoimage
12
Jun 2, 2009 02:34 PM
