loud whirling noise coming from the rear
Old Jun 23, 2007 | 12:05 AM
dj_zyx's Avatar
Default loud whirling noise coming from the rear
my center caps were not on the car when i bought it and haven't been for quiet some time
i hear a loud whirling noise could that be the bearings?
if so is it hard to replace?
btw i have a 93 honda hatchback, maybe im not used to it...
Old Jun 23, 2007 | 12:12 AM
motor_man's Avatar
Default Re: loud whirling noise coming from the rear (dj_zyx)
i used to have a hatch, lots of noises from the back but in ur case it might be different idk?
Old Jun 23, 2007 | 04:18 AM
crvtt717's Avatar
Default Re: loud whirling noise coming from the rear (motor_man)
I had a similar noise coming from my front and the problem was wheel bearings. I dont know if I could describe it as whirling though. It was more like a...well i guess whirlling could describe it.
Old Jun 23, 2007 | 04:59 AM
n.famous.1's Avatar
if your bearings arent shot completly after a while of hearing it and trust me youll notice.....it could be your rear suspension...i had a bent trailing arm and the aligment made it sound all wierd especially after the tires started going out.
Old Jun 23, 2007 | 05:57 AM
burnitdown's Avatar
could be your tires even
Old Jun 23, 2007 | 06:11 AM
97Ej6mike's Avatar
Default Re: (burnitdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnitdown &raquo;</TD></TR><TR><TD CLASS="quote">could be your tires even</TD></TR></TABLE>
Check your tires pressure. A low tire will make a 'whirling' noise as it rides along. Also keep in mind that different Tarmac surfaces and types make noises when driven over.
Old Jun 23, 2007 | 09:56 AM
dj_zyx's Avatar
Default Re: (97Ej6mike)
thanks for all your posts!
umm its not the tires i have Toyo T1-S tires they never made that sound on my del sol when I had them on the car.
my suspension is all tight just installed new rear arm shocks and neuspeed springs
the reason why i think my bearings are making the noise is because some retard grinded off the oem center caps.
urgh such headache now... what do you guys recommend doing to place the part. I have drum breaks in the back should i just change the whole assembly? or just order a part of ebay like this one?
http://cgi.ebay.com/ebaymotors...ZWD1V
now sure if that will go...
Old Jun 28, 2007 | 07:48 PM
n.famous.1's Avatar
might as well, if you have the cash. if you get rear discs and have the cash try to get a 40/40 valve.
HondaGuy951
Mar 5, 2011 08:41 AM
teg_dc2
Oct 16, 2008 09:37 PM
matix
Jun 28, 2006 03:18 PM
codyb13
Apr 14, 2005 05:41 PM
johnqt3
13
Dec 12, 2004 08:26 AM
