Can XTD stage 3 clutch cause Problems
Old Jun 22, 2007 | 06:20 PM
LukieLuc's Avatar
Default Can XTD stage 3 clutch cause Problems
So i have had this clutch in for about 5,000 miles, still grips hard, at any RPM. My problem is that it rattles when i shift while in 1st to 2nd at about 2500-3000 rpm and does the same thing in 3rd. It only does this when driving around town (normal driving conditions). Is this because i have OEM Flywheel? Will an Exedy stage 1 organic clutch do the same thing with Fadanza 8 pound flywheel?
Old Jun 22, 2007 | 06:21 PM
98vtec's Avatar
moderator emeritus
Default Re: Can XTD stage 3 clutch cause Problems (LukieLuc)
how do you know the clutch is rattling? If its rattling, that means something is loose.....which is not good.
confirm how you know its the clutch.
Old Jun 22, 2007 | 06:35 PM
LukieLuc's Avatar
Default Re: Can XTD stage 3 clutch cause Problems (98vtec)
when i am releasing the clutch and it starts to engage with the flywheel, thats when it makes a sound like they are moving at completely different speeds, is that because i have a oem flywheel? it has the worse ride around the town, especially when coming from a stop
Basically its like he tranny shakes, and the wheel on that side does also, when going in reverse when the clutch is trying to engage
Old Jun 22, 2007 | 06:57 PM
117's Avatar
117
Is it a metallic puck type clutch? If so, what you're describing is normal. Did you resurface the flywheel friction surface? If not, that is probably aggravating the problem.
Old Jun 22, 2007 | 07:01 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">when i am releasing the clutch and it starts to engage with the flywheel, thats when it makes a sound like they are moving at completely different speeds, is that because i have a oem flywheel?</TD></TR></TABLE>
they ARE moving at different speeds.
what you are describing is very similar to clutch chatter.
Old Jun 22, 2007 | 07:37 PM
LukieLuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
what you are describing is very similar to clutch chatter.</TD></TR></TABLE>
yea exatcly, is that normal? Can it hurt my mounts or tranny? Everytime i realse the clutch to hard after shifting it jults the car foward or it makes other things clank(make noise) in the engine bay?
I will be going to To college in New york city towards the beginning of september would it be wise for me to replace the clutch with an Exedy stage one organic clutch?
Ps the car is a Daily Driver
Old Jun 23, 2007 | 10:35 AM
my9thtry's Avatar
dude just buy a good clutch that garbage is not worth you aggrivation. it will break down on you if your going to be in new york, thats some of the hardest driving your car will ever see.
Old Jun 24, 2007 | 08:15 AM
lude98SH's Avatar
x2
Old Jun 24, 2007 | 08:19 AM
k_lude's Avatar
Default Re: Can XTD stage 3 clutch cause Problems (lude98SH)
i say resurfacing also or the bearings...most likely you would need to resurface it.
Old Jun 24, 2007 | 08:24 AM
WhiteBB2's Avatar
Default Re: Can XTD stage 3 clutch cause Problems (k_lude)
XTD sux! I used them for about 7k miles and then my clutch crapped out on me.
looked like this:
Old Jun 24, 2007 | 08:27 AM
LukieLuc's Avatar
Okay, so would you guys suggest I get another clutch? Would an Exedy stage 1 organic clutch give me a smooth shift while driving around town & grip when I want to shift at high rpms?
Old Jun 24, 2007 | 08:30 AM
WhiteBB2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">Okay, so would you guys suggest I get another clutch? Would an Exedy stage 1 organic clutch give me a smooth shift while driving around town & grip when I want to shift at high rpms?</TD></TR></TABLE>
When I replaced my clutch recently I went with Exedy Stage 1...Its nice.
Old Jun 24, 2007 | 08:58 AM
NTX
Guest
Posts: n/a
Default Re: Can XTD stage 3 clutch cause Problems (WhiteBB2)
dont fukn cheap out/buy ebay stuff for **** like clutch/suspension
Old Jun 24, 2007 | 10:20 AM
lude98SH's Avatar
Default Re: Can XTD stage 3 clutch cause Problems (NTX)
ive heard many good things about the stage3 however
Old Jun 24, 2007 | 10:37 AM
NTX
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">ive heard many good things about the stage3 however </TD></TR></TABLE>
me too, but id rather spend a lil more and buy proven products; not just things i heard about it do it right the first time
UNLTD
Nov 12, 2006 09:41 PM
reset2k
Apr 12, 2006 05:15 PM
IntegraJdmb18c1
Jan 16, 2006 02:16 PM
allstockb18c
Jul 3, 2005 12:44 PM
Toretto
Feb 25, 2003 08:51 AM
