some questions...
Old Jun 22, 2007 | 03:04 PM
shaylude's Avatar
Default some questions...
Ok, i have an h23a1 tranny
im buying a h23a (vtec) motor
so...the tranny and everything should bolt up perfectly right??
also..about wiring the vtec??
where would i start?
would i need a new ecu?
Old Jun 22, 2007 | 03:10 PM
dagle's Avatar
Default Re: some questions... (shaylude)
i thought h23a was non-vtec.. H22 is vtec
and yes the H series tranny should bolt up.
Old Jun 22, 2007 | 05:49 PM
shaylude's Avatar
Default Re: some questions... (dagle)
thts what i thought too but i keep finding them with vtec
Old Jun 22, 2007 | 05:56 PM
WhiteBB2's Avatar
there is an H23a1 USDM which is NON VTEC and then a JDM H23A which is VTEC like the H22A
Old Jun 22, 2007 | 09:21 PM
Hawkze_2.3's Avatar
The trannies will definately bolt up, and for the VTEC stuff, just read the FAQs and look for swapping in H22s. Lots of info...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">i thought h23a was non-vtec.. H22 is vtec
and yes the H series tranny should bolt up.</TD></TR></TABLE>
The H23A is a 2.3 liter VTEC engine from the Euro-R Accord and I have read the Prelude Type-S. The H23A1 is the non-VTEC H23 you're used to seeing here in the states.
Old Jun 23, 2007 | 01:36 AM
shaylude's Avatar
Default Re: some questions... (Hawkze_2.3)
no its in canada
Old Jun 23, 2007 | 06:27 PM
shaylude's Avatar
will like the throttle body and etc.etc. fit on the h23a fine
Old Jun 23, 2007 | 10:11 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaylude &raquo;</TD></TR><TR><TD CLASS="quote">no its in canada</TD></TR></TABLE>
OK, same thing except for the names of the trim levels and some little options. I'm pretty sure you guys didn't get the H23 VTEC.
Old Jun 24, 2007 | 01:26 AM
shaylude's Avatar
Old Jun 24, 2007 | 12:48 PM
shaylude's Avatar
also, what ecu would i need to run this engine with?
and, with the h23a1 engine harness will i need a different harness or anything???
Old Jun 24, 2007 | 12:49 PM
shaylude's Avatar
and...what rpm does vtec hit in the h23a??
what rpm does it redline....etc. etc.
Old Jun 24, 2007 | 06:28 PM
my9thtry's Avatar
if that thing doesnt come with and ecu to run it i would just buy a P28 with base from http://www.Phearable.net .
Old Jun 24, 2007 | 07:13 PM
Televator's Avatar
The H23A is from the Accord SiR wagon...Found nowhere else as far as I know... and yes the H23A1 tranny will fit.
Old Jun 24, 2007 | 08:01 PM
marks_lude's Avatar
Default Re: some questions... (Televator)
i might be wrong, but didnt that thing only come in auto in the accord wagons? if thats so, you have to make ur own tuned ecu to run it (unless u actually are auto)
Old Jun 24, 2007 | 08:32 PM
flavah0wnz's Avatar
Default Re: some questions... (marks_lude)
im almost positive u can run a p13 or an chipped p28 or p06
Old Jun 24, 2007 | 08:34 PM
mgags7's Avatar
it would probably run just fine on a p13, though tuning it is the best choice.
op: the ecu determines when vtec engages, so that depends on your choice there.
sony224422
Aug 3, 2009 05:45 PM
"ANONYMOUS"
Jun 26, 2008 09:45 PM
92integraVTECgsr
Jan 22, 2007 12:26 PM
masteryoda10
Feb 24, 2006 02:57 PM
Boostless-Lude
Jan 4, 2004 10:49 PM
