if i.......
Old Jun 22, 2007 | 02:56 PM
em1_racer's Avatar
Default if i.......
if i lower my car 2.5" inches in front and 2.3" in back would i need to adjust my camber and toe?
car= 2000 civic si
wheels=195/50/15
also which would go better with H&R race springs koni yellows or tokiko illuminas?
Old Jun 22, 2007 | 02:57 PM
em1_racer's Avatar
Default Re: if i....... (em1_racer)
not sure if this is the right place to post this.....
kuja396's Avatar
yes
Old Jun 22, 2007 | 03:36 PM
lechuza05's Avatar
Default Re: if i....... (kuja396)
Most definitely. Especially toe! I like the negative camber for cornering, but you will HAVE to get the toe aligned or BYE BYE TIRES!
Old Jun 22, 2007 | 03:41 PM
Agent_EM1's Avatar
Default Re: if i....... (lechuza05)
I think anything beyond 1.5" requires the need to adjust toe. I had my old Civiclowered about 1.75" on Tanabe GF210's and Koni Yellows... I thought I needed a camber kit, but I just told the shop to align it and was told to tell them to adjust the toe to 0 or as close to 0 as possible. The alignment shop aligned it and I drove it for half a year (before it was stolen) and about 4,000 miles or more. Never had uneven tire wear at all. Everything was straight...
Old Jun 22, 2007 | 04:30 PM
em1_racer's Avatar
Default Re: if i....... (Agent_EM1)
so do i need some aftermarket camber kits or just stock?
Old Jun 22, 2007 | 07:11 PM
em1_racer's Avatar
like skunk2 or something?
Old Jun 22, 2007 | 07:14 PM
Mr.EM1_EK's Avatar
yeah, or you could go with blox, they make good kits also. iv'e heard alot of negative stuff about skunk 2 camber kits slipping.
Old Jun 22, 2007 | 08:46 PM
em1_racer's Avatar
Default Re: if i....... (Mr.EM1_EK)
yea i heard some negative things from them too
Libertariat's Avatar
Ek Forever y0!
You don't need a camber kit for that drop.
The front camber won't be bad enough to need to mess with it, and two washers on each UCA bolt will correct your camber enough in the rear to make your camber trackable and have suitable wear for daily driving.
A little camber is perfect. The toe is what eats tires.
Old Jun 22, 2007 | 08:57 PM
em1_racer's Avatar
Default Re: if i....... (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">You don't need a camber kit for that drop.
A little camber is perfect. The toe is what eats tires.</TD></TR></TABLE>
u have the H&R race with konis or something so you know more...so i dont really need to buy some aftermarket cambers for it then...just put washers on them?
cuz i ordered a set of h&r race springs and koni yellows so i was just wondering...ill take your advice since you know more about it then me.
what about the toe do i need to fix that? or will it be ok?
Old Jun 22, 2007 | 09:02 PM
Ek Forever y0!
**had** H&R races. My new car is still stock.
Toe can be adjusted by the alignment shop. Toe is VERY Key in normal tire wear, it usually gets out of spec when you lower your car any amount.
When you get it aligned tell them to ignore the camber, just set the toe to 0 or factory settings.
Old Jun 22, 2007 | 09:04 PM
em1_racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">**had** H&R races. My new car is still stock.
o...ok thanks alot mr ek guy
mish__
Suspension & Brakes
Sep 14, 2011 09:02 PM
em1_racer
Suspension & Brakes
Jun 27, 2007 09:24 AM
texx
Honda S2000
Feb 26, 2006 01:54 PM
GUNNER666
Jul 28, 2004 08:26 AM
Robstunner4
Jul 25, 2004 11:26 PM
