no a/c
Old Jun 22, 2007 | 02:27 PM
nguyen726's Avatar
Default no a/c
i got a 99 cx hatch. the car never had ac...i tried searching couldnt find nething.so if u can help me. what do i need to add a/c.....i am planing to do a swap so the swap will come with the ac compressor..and i will need to get the condensor fan. do i need any components under the dash?..and theres no ac button..and is there any fuses i need to add?
Old Jun 22, 2007 | 02:56 PM
VAAJ's Avatar
Default Re: no a/c (nguyen726)
good luck buddy, theres not much air condition info here on honda-tech.
I'll give you some idea on what you'll need. Your civic is a AC virgin so you'll need lots of stuff.
Parts you need:
Condenser
Condenser fan
Compressor
Compressor bracket
Idler pulley, mounts on the compressor bracket
belt
receiver & drier (must buy new unit)
Evaporator Assembly
lots of AC pipe and hose
fan relay
compressor clutch relay
dash switch
harness, plug onto fan, compressor, temperature sensor
misc brackets and clips
You can save money by buying used part, but some stuff should be bought new.
jdmkha
Apr 16, 2009 03:44 PM
stockEJ
Aug 6, 2008 06:46 PM
stockEJ
Aug 6, 2008 06:45 PM
needforvtec
Dec 1, 2007 03:26 PM
old man honda
Apr 14, 2006 07:01 AM
