-->Running like crap after compression test..? Please Help!<--
Old Jun 22, 2007 | 11:42 AM
ZCBlackEG's Avatar
Default -->Running like crap after compression test..? Please Help!<--
-&gt;Okay... I did a compression test on my car the other day (which is a 93 civic ex coupe with a JDM ZC sohc vtec swap)..
-&gt;Did not disconnect distributor or take out any fuses just went at it.. Compression turned out excellent but when i turn the car back on it runs like crap..
-&gt;I cant go over 3500 rpm and it breaks up all throughout the rpms i do have.. Changed the plugs hoping that maybe i just fouled a plug but no..
-&gt;And also i am throwing a 4 CEL code.. And that is the crank positon sensor and i do not have one of them.. Could it be a problem with the distributor or what? I do not know.. Thank you for any help
Old Jun 22, 2007 | 11:50 AM
EJ2*Whitey's Avatar
Default Re: -->Running like crap after compression test..? Please Help!<-- (ZCBlackEG)
You muffed up yur car..go0d job
Compression Test: (please read next time..its not that damn complicated)
- Normal operating temperature
- Disconnect fuel and ignition system..dont want sparks or raw fuel sitting down in the cylinder
- WOT
- Remove ALL spark plugs
- Crank the engine over 4-6 times
- Cylinders should have atleast 120psi.
Old Jun 22, 2007 | 11:54 AM
ZCBlackEG's Avatar
Default Re: -->Running like crap after compression test..? Please Help!<-- (EJ2*Whitey)
Okay i know that now but i cant turn back time.. What do i need to replace what went wrong? I have turbo parts on way for next weekend and need to have her right for the track..
Old Jun 22, 2007 | 11:59 AM
EJ2*Whitey's Avatar
You have turbo parts on the way when your car doesn't even run right? Your a genius.
Old Jun 22, 2007 | 12:02 PM
ZCBlackEG's Avatar
They were on the way before i did the compression test buddy
Old Jun 22, 2007 | 12:14 PM
ZCBlackEG's Avatar
Please Help
canabiscris
Nov 18, 2013 10:53 AM
KayTran
May 12, 2008 09:59 PM
cornhusker
Sep 21, 2003 07:02 AM
BlackB18CTeg
Mar 24, 2003 08:44 PM
