*HELP* Another PASS inspection OBDII car OBDI ECU
Searched it and nothing has helped so far.
Situation:
.: 1999 Civic Si (OBDII)
.: J.spec B18c (OBDI)
.: Does have a cat and sensors
.: Throws a CEL if I accelerate hard
Need a way to pass inspection in Upstate NY...LMK what all you swapped guys are doing
Situation:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">Put the stock p2t ecu in, drive normally for about an hour. no cel, go get the inspection done immediately.</TD></TR></TABLE>
Where can I get that ECU? And it will deffinately allow my engine to run fine?
edit: you have a jdm gsr....no crank sensor is a big problem. not a really easy way to pass legally without some parts being put on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">edit: you have a jdm gsr....no crank sensor is a big problem. not a really easy way to pass legally without some parts being put on.</TD></TR></TABLE>
I think ive found a solution...ill revive this thread if it doesnt work out
RACEPAK
Nov 24, 2007 02:45 PM
so simple
Dec 13, 2004 08:12 AM
