knock sensor
Old Jun 22, 2007 | 10:56 AM
B16tyler422's Avatar
Default knock sensor
i have a B16A in a 91 hatch and the knock sensor is busted do i have to run one cause ive been told i dont really have to
Old Jun 22, 2007 | 11:01 AM
cb07's Avatar
I don't suppose you HAVE to, but it'd be nice. You do know what knocking is, right?
Old Jun 22, 2007 | 11:03 AM
yz125rider21's Avatar
all depends on what ECU you are running...if you have a obd-0 or p28 then dont worry about it.
Old Jun 22, 2007 | 11:08 AM
4g hatch's Avatar
if its a dual cam vtec ecu then u need it or you'll be in limpmode. you can have them reprogramed not to look for them. the p28 youll need to have "chipped" for a dual cam
Old Jun 22, 2007 | 08:07 PM
Default Re: (4g hatch)
its a pwo ECU
Old Jun 22, 2007 | 08:13 PM
yes you need it if thats the ecu your running so get one off ebay or the junk-yard and be on your way.
Old Jun 23, 2007 | 04:57 PM
Default Re: (yz125rider21)
what should i get it from 91 integra or does it have to be for a Vtec motor?
Old Jun 23, 2007 | 08:50 PM
Crx Jimmy's Avatar
Default Re: (B16tyler422)
Either spend $40 on a used knock sensor or spend $70 to get your ecu socketed and chipped to not look for the knock
Old Jun 23, 2007 | 11:14 PM
Default Re: (Crx Jimmy)
will any B series knock sensor work or do i need one from a Vtec motor like a 99 si or 95 delsol b16a3
Scotty B
Mar 26, 2021 03:15 PM
88crxdxfastwhip
Feb 1, 2010 02:17 AM
MONSTERek4
Jul 9, 2009 07:25 PM
PanamaVTI
Nov 26, 2003 10:39 AM
Spoon_Civic
Jan 12, 2002 07:42 PM
