Help: Throttle Cable for B series in 1994 civic
Old Jun 22, 2007 | 09:23 AM
94b16coupe's Avatar
Default Help: Throttle Cable for B series in 1994 civic
I tried searching for this with mixed results......
I recently bought a 1994 Acura Integra LS throttle cable to use on my B20/vtec setup in a 1994 civic coupe.
One end of the Integra throttle cable looks like a dime shaped circle, the other end looks like the normal termination for the throttle cable. My gas pedal in the civic looks to need the same termination as the one going into the throttle body, Is there a reason people suggest buying the Integra throttle cable for the Eg? or is this another case of people speaking BS on honda-tech?
I know that people use the stock throttle cables for this swap btw.
Thanks in advance for the help.
Old Jun 22, 2007 | 09:27 AM
egsleepercivic's Avatar
you have the correct, idk what the problem is ????
Old Jun 22, 2007 | 09:45 AM
averyvm's Avatar
Default Re: (egsleepercivic)
I hope everything works out
Old Jun 22, 2007 | 10:30 AM
94b16coupe's Avatar
Default Re: (averyvm)
figured it out....
the car used to be an automatic, the auto pedal was never changed to a manual one. the throttle cables are diffrent for automatics....that was the problem.
BryanM.
Jan 10, 2022 04:16 PM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
rolledthatho
Sep 9, 2005 10:29 AM
6shootahorsenamedtrigga
Oct 2, 2004 04:32 PM
dustywebber
Jul 10, 2004 09:04 AM
