Sqeaky suspension
Old Jun 22, 2007 | 09:00 AM
jdmh22luda's Avatar
Default Sqeaky suspension
Hey guys, I have had my suspension on for about 1 1/2 yr and it has started to sqeak just recently and still rides fine.
I was just wondering if the struts were blown or maybe just a lack of lubrication or bad bushings. Sus. technique springs with tockico blues
Old Jun 22, 2007 | 10:50 AM
jdmh22luda's Avatar
Default Re: Sqeaky suspension (jdmh22luda)
help me pleassseee??
Old Jun 22, 2007 | 11:09 AM
Giant_Bean's Avatar
I've never heard of blown shocks squeaking (could be wrong though), but most likely it is a bushing problem. Have a buddy bounce the car while you poke you head around(without getting squashed) and see if you can hear where it is coming from.
Old Jun 22, 2007 | 03:50 PM
Cottonwoodz's Avatar
lower ball joints
Old Jun 22, 2007 | 04:50 PM
2.2lude88's Avatar
Default Re: (Cottonwoodz)
WD40 works everytime!!! jk
Old Jun 25, 2007 | 07:42 AM
jdmh22luda's Avatar
Default Re: (2.2lude88)
pretty sure wd40 won't fix this problem, ill check the ball-joints when i get off work. The body does have almost 150k so im sure the rubber is pretty beat up
Old Jun 25, 2007 | 07:47 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">lower ball joints</TD></TR></TABLE>
bad lower ball joints won't cause a "squeak" like that. My vote is bushings.
Old Jun 25, 2007 | 11:31 AM
jdmh22luda's Avatar
Default Re: (mgags7)
yeah i was thinkn bushings to, gags u play on bodog?
Old Jun 25, 2007 | 12:47 PM
E-Money's Avatar
Default Re: (jdmh22luda)
front sway bar bushings, radius rod bushings
Old Jun 25, 2007 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
bad lower ball joints won't cause a "squeak" like that. My vote is bushings.</TD></TR></TABLE>
You are telling me that lower ball joints dont squeak, when bad?? You, need to read your helms somemore.
Push down on your front end... up, and down, up, and down.... Balljoints
I got 240k miles on my stock bushings... never squeaked.. Ball joints lasted 170k
Old Jun 26, 2007 | 05:30 AM
jdmh22luda's Avatar
the squeak is definetly obvious when you press up and down on the suspension, so i am assuming this could still be a number of things..or could it be lowered to ball joints?
Old Jun 26, 2007 | 12:44 PM
spray some WD40 on them, and let it soak in.. if its your lowers the squeak will go away, for acouple of weeks
turbotime
12
Jun 18, 2006 08:55 AM
WTB AUTO EK
Jan 4, 2006 12:31 PM
beaterman
Dec 1, 2005 03:35 AM
jerbear!
Suspension & Brakes
Feb 9, 2005 04:10 AM
REDBARON
Jun 10, 2001 03:50 PM
