Can I?
Please make better thread titles. Thread title should be descriptive and inform the reader about what is being asked/discussed within the thread.
and to answer your question, it depends on the spring you choose.
go back and read the thread I gave you in your last thread. Next to some of the different springs they say if it can be used with OEM shocks or if they need aftermarket shocks.
The thread doesn't say whats needed it just tells you whats good. I want to know if I need new shocks or anything else. I'm planning on just buying shocks of ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998accord »</TD></TR><TR><TD CLASS="quote">The thread doesn't say whats needed it just tells you whats good. I want to know if I need new shocks or anything else. I'm planning on just buying shocks of ebay.</TD></TR></TABLE>
It is better to get new shocks. OEM shocks are designed for a specific springrate and ride height. Getting an aftermarket one will be better.
hmmm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">CHAPTER 1-LOWERING SPRING
1)Lower spring-it helps to reduce body roll,etc a.k.a.
help you goes around the corner with more grip by increasing the degree of negative camber.
there's a bunch of lowering springs in the market but only a handful of those spring are actually performs well, in the street as well as the track. I come with warranty, registtion card, spec sheet for cutting the bumpstop and a pair of decals.
1)eibach-probably one of the most popular lowering spring maker in the US market today, they offer two type/style of spring for accords, they are eibach prokit and sportline. I personally love how the eibach ride in the street.
a)PROKIT is designed and road test with use in conjunction of OEM stock shocks in mind, so it's okay to use stock shock with prokit, in fact i had the same set up before.
*note: some people experience the "boat look" with eibach prokit, boat look=the front is higher than the rear.
b)SPORTLINE sits some what lower than prokit, sporline requires an aftermarket(stiff damper) shocks. Sportline is pretty much the lowest you can go without rubbing.
2)H&R-another popular spring makers, offering three type of spring for accord.
They are the cheaper alternative to eibach, which like eibach, their springs are very good in quality.
a)O.E. SPEC spring- they are what my friends called "***** drop", it lower the car like less than an inch or so. they are built with a higher spring rate=stiffer ride. Perfect for sleeper, i guess.
b)SPORT-another ultra popular springs for the honda crowd, they are cheap and works, need aftermarket shocks to accompany the increased rate.
c)RACE-the low-est spring h&r offer, you'll need to throw in some aftermarket shocks for this springs also. They are progressive spring, alot of people experience some "clunking" when the lower part of the coil hit each other when the spring is compressed.
3)Tein-the green suspension company from Japan, they got some amazing stuff with a reasonable price. Not the best in the world but top notch stuff right here
They only offer one type of lowering spring for accord, to my surprise, s-tech didn't live out the tein reputation.
a) S-tech-The entry level spring to the bigger coil-over brother. They are inexpensive to begin with, they are designed to used with oem stock shock but they fall short on the performance side. Some of my boy with those s-tech, claim they are way too soft even with an aftermarket shocks.
4)Tanabe, tanabe USA offer number of springs for honda, not much actual info at this point yet.</TD></TR></TABLE>
hmmm...
portaman03
Suspension & Brakes
Jun 1, 2007 10:12 AM
