Engine idle's drops below 1000rpm and even cuts off
I have a 93 Si VTEC, and the engine idles very low at times and even up to nearly 2000rpm when cold, the engine has also cut off a few times due to the idle rpm falling very low.
search, bro. top right corner.
https://honda-tech.com/zerothread?id=1979500
this thread should help though.
It is supposed to idle high when cold, that is a feature of the FITV (fast idle thermal valve)
The car is supposed to idle warm at 750rpm +/- 50rpm.
If it is shutting off sometimes clean out the throttle body, FITV and the IACV. Hit up the search to figure that out.
Shauntron
Apr 25, 2007 12:06 AM
