Need some help.....front window wipers...
Old Jun 21, 2007 | 09:31 PM
igone916's Avatar
Default Need some help.....front window wipers...
Here's the problem, my girl's car was stolen. After they found it, the key cylinder was broken. I decided to fix it myself. After installing the key cylinder my front window wiper does not work. All on the functions on the right switch works except the front wipers. I checked the fuses and it was fine. What could be the problem? Do the wipers have any connection to the key ignition? What do I need to check? Please help if you can....Thanks for looking............
Old Jun 21, 2007 | 10:35 PM
cosmokramer's Avatar
Default Re: Need some help.....front window wipers... (igone916)
hmm...mabye they just broke the switch? Try swaping a spare on in there (if you have one) to see if this is the problem.
Old Jun 22, 2007 | 09:46 AM
igone916's Avatar
Default Re: Need some help.....front window wipers... (cosmokramer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cosmokramer &raquo;</TD></TR><TR><TD CLASS="quote">hmm...mabye they just broke the switch? Try swaping a spare on in there (if you have one) to see if this is the problem.</TD></TR></TABLE>
Thanks, but how do you take off the wiper switch. I took off the two screws that holds on with the white plastic piece but it does not come off. Are there more screws? Do I have to take off the steering wheel? Has anyone replace this before, if so please help...Thanks.
Old Jun 23, 2007 | 04:34 PM
igone916's Avatar
help...
Old Jun 24, 2007 | 11:23 AM
Nataku's Avatar
I have the whole switch assembly (pictured above, part number 7) for sale if you need it. It is from my 96 GSR.
Old Jun 24, 2007 | 12:13 PM
igone916's Avatar
Default Re: Need some help.....front window wipers... (Nataku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">I have the whole switch assembly (pictured above, part number 7) for sale if you need it. It is from my 96 GSR.</TD></TR></TABLE>
how much do you want? How did you take it off? I took of the two screws but it won't move. Are there clips holding it?....
Old Jun 24, 2007 | 12:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
After removing the steering wheel cover, you remove the two screw (which you done). There should be an electrical connector plug in the back, disconnect that, and it should come out.
Old Jun 25, 2007 | 09:05 PM
igone916's Avatar
Default Re: Need some help.....front window wipers... (tech8)
thanks...i will try it again...
pinoysi2000
Oct 14, 2012 09:37 PM
PhantomLord
Audio / Security / Video
Apr 18, 2009 05:56 PM
accordredliner
Sep 25, 2005 02:34 PM
