F20b specs??
Old Jun 21, 2007 | 07:21 PM
hahaha38's Avatar
Default F20b specs??
Well what I want to know are some specs.Anybody played with them?? Id like to know the rod length. piston skirt length with where the rod bushing goes. Whats the throw on the crank?Like what size are the mains and rods. Int/Exh valve sizes. What are the stock cams ground at. And thats all I can think of for now.Thanks for any help in advance guys.
Old Jun 22, 2007 | 02:53 PM
Loco-B's Avatar
Default Re: F20b specs?? (hahaha38)
those are some good questions.
i've got a few good answers. This info was taken from a Japanese repair manual I have for the JDM/UKDM 5th Gen CF chassis Accord.
deck height = 8.643
bore = 85mm/3.346
Cylinder Head
combustion chamber volume = 53.8cc
intake valve dia. = 34mm
exhaust valve dia. = 29mm
head gasket bore = 86mm
head gasket thickness = .026
pistons
piston dia. = 85mm/3.346
compression height = 1.221
wrist pin dia. = .866
Crankshaft
stroke= 88mm/3.464
main journal dia. = 55mm
rod journal dia. = 1.771
rods:
length = 5.709
width = .935
be bore = 1.890
pin bore = .8649-.8654
Modified by LocOBanAnA at 2:20 AM 6/23/2007
Old Jun 22, 2007 | 07:18 PM
hahaha38's Avatar
Wow thanks for the info thats exactly what I was looking for.
Old Jun 22, 2007 | 07:19 PM
Loco-B's Avatar
Default Re: (hahaha38)
Old Jun 22, 2007 | 08:12 PM
hahaha38's Avatar
Hay would you happen to know the compression height of an f20c would you?? Or would you be able to point me in the direction of where I could find that info?
Old Jun 22, 2007 | 09:28 PM
machine4321's Avatar
search in the lude forum ...there is a h/f faq thread i forget whats the title is but it may have it in there ...
so what the plans for your f20b
Old Jun 22, 2007 | 11:25 PM
Loco-B's Avatar
Default Re: (machine4321)
i dont think there are any listing for the F20c in that thread.
just the accord f22's, f20b, and the h22's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahaha38 &raquo;</TD></TR><TR><TD CLASS="quote">Hay would you happen to know the compression height of an f20c would you?? Or would you be able to point me in the direction of where I could find that info?</TD></TR></TABLE>
yeah....go to your local bookstore. Locate a chiltons, or haynes manual for a s2000. Most of those repair manuals have specs from the factory printed. If your trying to get info for Japanese motors you might have better luck trying to find an importer here in the states to get you a repair manual from overseas.
Old Jun 23, 2007 | 01:53 PM
hahaha38's Avatar
Ive pretty much looked through all the threads on specs in here. Mainly they show hp and tq specs. What im thinking of doing is a f20B with 6.0 length rods special pin location and compressin height. So with 25+ pounds of boost I want 550 at the wheel with about a 12k redline. Ive already found some body that will make me the parts I just need the specs. But yeah thats the plan atleast.LOL. And thanks again for the info ill just keep looking for the rest.LOL
ge_itr
Jan 24, 2008 09:59 AM
White Lightnin
Jul 23, 2004 06:06 AM
Train
Mar 21, 2004 10:23 PM
omega11855
Dec 28, 2003 04:21 PM
Mr. Vapor
Jan 16, 2003 09:34 PM
