what front forks did you use in your h22 swap in your ef?
Old Jun 21, 2007 | 04:20 PM
projectef's Avatar
Default what front forks did you use in your h22 swap in your ef?
i have a h22 swap in my 88 ef, and when i did it, for some reason, when i put the axles in (hasport) with the stock forks in, the axles where touchin the forks a lot, like the axles was 2 big. so what i did was gring the hell out of the forks so it could fit, and not touch. is that normal or what?
Old Jun 21, 2007 | 09:09 PM
crx22's Avatar
Default Re: what front forks did you use in your h22 swap in your ef? (projectef)
flip sides with them so there is more room I think it was....its been so long since I did it...I'll have to look tomarrow.
Old Jun 21, 2007 | 10:18 PM
projectef's Avatar
aight
Old Jun 21, 2007 | 11:05 PM
Bob_760's Avatar
Default Re: (projectef)
DA Integra forks have identical geometry/fitment and are much wider. I have them on my CRX because now I can put B-Series axle joints straight through them without having to take them off the LCA . The only way they may not work is that they are only wider on one side. The side that bends outward is way wider but the straight side is still straight. I can get a pic if you want.
-Kurt
Old Jun 23, 2007 | 02:41 PM
projectef's Avatar
if u can get a pic, thats koo
Old Jun 23, 2007 | 02:57 PM
CRXBart's Avatar
Default Re: what front forks did you use in your h22 swap in your ef? (crx22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx22 &raquo;</TD></TR><TR><TD CLASS="quote">
flip sides with them so there is more room I think it was....its been so long since I did it...I'll have to look tomarrow.</TD></TR></TABLE>
I did a H22 swap in a EG, with Hasport's newest version mounts and I had to switch sides. Not sure if the EF is the same.
Old Jun 23, 2007 | 04:06 PM
projectef's Avatar
what do you mean swith sides? like right side to the left side, or just flip it, so the curved side is towards the car.
Old Jun 23, 2007 | 04:33 PM
yz125rider21's Avatar
Default Re: (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">DA Integra forks have identical geometry/fitment and are much wider. I have them on my CRX because now I can put B-Series axle joints straight through them without having to take them off the LCA </TD></TR></TABLE>that true???have to research that and I might go that route to save me time swapping out axles when they snap. anyone wanna vouch for this?
Old Jun 23, 2007 | 04:37 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean swith sides? like right side to the left side, or just flip it, so the curved side is towards the car.</TD></TR></TABLE>
So the bow goes to the back no the front.
Old Jun 23, 2007 | 05:48 PM
projectef's Avatar
and use the stock one or the da forks?
Old Jun 23, 2007 | 08:25 PM
Crx Jimmy's Avatar
Default Re: (yz125rider21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">that true???have to research that and I might go that route to save me time swapping out axles when they snap. anyone wanna vouch for this?</TD></TR></TABLE>
Yes that is definitely true. The da forks are identical but are wider and can fit the axle right through. I loved this when I had my DA it made axles changes take 10 minutes I would be still running them but Im using the eg forks because I got a deal on EG coilovers
Old Jun 24, 2007 | 07:07 AM
projectef's Avatar
aight thanks for the info.
Einhander276
16
Mar 11, 2012 07:09 AM
90blackcrx
Oct 5, 2009 05:35 AM
ketchup
May 19, 2008 12:13 PM
