Black as a.... well u pick one that wont offend
Old Jun 21, 2007 | 03:54 PM
s_vares's Avatar
Default Black as a.... well u pick one that wont offend
Im by no means new to cars or auto repair. But as most of you know I have a 97 Base
Got it a few months back. love it.
But....
Last night I had it floored to redline in 3 gears as my buddy was on my *** in his s2000.
He said my exhaust was very black and smelt super rich. I know rich is normal but my car is rediculas.
WHat do you guys think?
New Fuel filter
Clean intake and egr ports
New plugs wires and cap/rotor
New PCV
No CEL
NEW O2 sensor ( wouldnt make diff at WOT anyhow)
but i do have cracks in my coil, whats the deal with that. but no problems starting or idle.
Thanks guys, and as you know im always willing to help.
Steve
Old Jun 21, 2007 | 04:09 PM
DCxMagus's Avatar
Default Re: Black as a.... well u pick one that wont offend (s_vares)
Probably cap and rotor first if it's about that time, might as well do the plugs and the wires as well. I know when I first bought my car I was planning to do that right away and a year later when I did it, my car pulled a lot harder and most the in my exhaust didn't come back after cleaning it out.
Although 5th gens run around a 11.5 AF ratio with a massive retard at the stock VTEC point. so there is no real way around getting all the soot gone, but yeah you shouldn't be puffing smoke, good sign your engine isn't igniting the mixture the entire way.
Old Jun 21, 2007 | 04:30 PM
veetak's Avatar
Ridiculous.
I'd start with tune up basics like plugs, wires, cap, rotor, clean/replace air filter...
You don't have some ebay tuner chip do you?
Old Jun 21, 2007 | 05:16 PM
typeS's Avatar
If you just got the car, it is possible that the last owner did not drive it like he stole it. This could just be a lot of buildup getting blown out. I would say go ahead and do the tune up basics as suggested above.
Old Jun 21, 2007 | 05:17 PM
typeS's Avatar
How many miles? Maybe some seafoam would be good before you change your plugs and oil.
Old Jun 21, 2007 | 09:29 PM
AndyD's Avatar
https://honda-tech.com/zerothread/689833
Rule 7.
Old Jun 25, 2007 | 04:51 PM
s_vares's Avatar
Im being as specific as I can.
CAR SMOKES BLACK.
all tune up been done, what more can I say
Plugs
Wires
Cap
Rotor
PCV
EGR clean (fixed many things)
Air filter
Fuel filter
Car has 90K miles
ALL STOCK excect lowered
Smokes mad black at high rpms.
Small puff of blue between shifts at redline.
No CEL new O2 sensor.
Thanks
Trying to see if this is normal.
Old Jun 25, 2007 | 05:55 PM
cleve's Avatar
Default Re: (s_vares)
try seafoaming it... my h22 lude has 200+ thousand on it and i did it and it ran a little better afterwards. is it a vtec? does it bog down at all in the rpm range? does the engine at idle sound normal to you? ticking of the valves?
Old Jun 26, 2007 | 08:06 AM
s_vares's Avatar
None of those problems.
Runs fine, getting 21MPG
and smokes black.
Valve were adjusted a few months back.
Old Jun 27, 2007 | 01:42 PM
cleve's Avatar
Default Re: (cleve)
thats a good idea get valve adjustment its like 50 dollars to do.
Old Jun 27, 2007 | 01:46 PM
s_vares's Avatar
no I just did that, bought the special tool for those recessed valvesl worked sick
im gonna check my fuel pressure and FPR ope
ration
eg6sir88
Jan 31, 2014 11:16 AM
Chriser0
20
Jan 16, 2014 08:02 PM
hatchizzle
Feb 23, 2013 07:09 PM
IntegraType-R
Aug 24, 2007 10:14 AM
gsrboi80
Jul 1, 2005 01:33 AM
