h22a4 crank in h22a1
Guest
Posts: n/a
i searched it and this is what i found.
https://honda-tech.com/zerothread?id=1232811
from what i see i can use my h22a4 crank in my h22a1 block correct. just need some verification. thanks.
hey....
97 h22a4 has 50mm mains and all 98-01 have 55mm mains...so youre going to need to find out what year it came off of.
There is one thing that most people do not know....not ALL 98 models came with the 55mm mains....only the ones manufactured IN 98...the 98 models that were made in 97 (if the car was bought between sept and dec of 97 its a 98 model year) have the 50mm.
argh i know its frustrating!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien »</TD></TR><TR><TD CLASS="quote">i think it was out of a 98 matt. im not totally sure. but i know its a h22a4. keep in mind this is the crank i spun a bearing so i had to get it turned. with that make a difference.</TD></TR></TABLE>
yes turning it will definitely make a difference, though you still won't be able to get it in your 50mm block without a serious line hone or some ridiculous turning down of the mains.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">measure the main and you will know.</TD></TR></TABLE>
. there is also a stamp on the exhaust side of the block to tell what year its from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlacktraxGirl »</TD></TR><TR><TD CLASS="quote">hey....
argh i know its frustrating! </TD></TR></TABLE>
You beat me to it..........damn Honda with their inconsistency! I guess they had to do something with the 97 blocks though. I don't understand why they even changed them in the 1st place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 »</TD></TR><TR><TD CLASS="quote">slightly off topic, but where exactly do you find the stamp that says is the bore is A or B size???</TD></TR></TABLE>
on the deck of the block, in the back, by the water pump.
