EGR h22 in civic wiring
'97 civic CX with '95 H22, (chassis is full OBDI converted). I went on a drive today, and it idles rough... it seems to fluxuate RPMS at idle, but not at in any predictable (repitative sp?) matter. Then, it threw an EGR code (I had not previously wired it). I tried to wire it, but I'm not sure if I idd it correctly... because it still idles bad, but better than it did. Can someone tell me how to wire the EGR? I also want to make sure the correct plug is plugged into the IACV... I'm not sure on that, although I'm not throwing an IACV code. Any wiring help is appreciated. Also, there is a black-solenoid looking thing that had a vacuum line from the manifold and another one running directly to the FPR.... I don't know what it is and didn't plug anything into it. Any thoughts?
i never hooked mine up. there is a way to ground it which should be even better than having it hooke up. i'll see if i can find out how again.....
still have yet to do it but here is what i was told.
take a11 and ground it. should be it. but like i said i have yet to do it to find out for sure. HTH
wouldn't it work just to unplug the IAB? I don't know it my seat-of-the-pants dyno is accurate enough to tell a difference
cccya
Apr 7, 2002 07:56 PM
