b-20 v tec with what kinda head???????
Old Jun 5, 2002 | 10:32 PM
shroomyman's Avatar
Default b-20 v tec with what kinda head???????
what the hell i cant decide on what kinda head to get to put on a 91 CRX with a b-20 and a type-R transmission.
Old Jun 5, 2002 | 10:59 PM
dustin's Avatar
Default Re: b-20 v tec with what kinda head??????? (shroomyman)
have fun w/ the hydro tranny
Old Jun 6, 2002 | 01:22 AM
.Ryan's Avatar
Don't Trust Anyone
Default Re: b-20 v tec with what kinda head??????? (dustin)
I would pick the kind of head without teeth.
Old Jun 6, 2002 | 04:11 AM
CRXGSR's Avatar
As you stated in your title, go with " v tec" head.
Old Jun 6, 2002 | 06:41 AM
02WRX's Avatar
Default Re: b-20 v tec with what kinda head??????? (CRXGSR)
My understanding is that a b16 head will give you higher compression than a b18c1 - I'm not positive on a b18c5 head, but if you can afford one, go that route - better valvetrain....
Eric
Old Jun 6, 2002 | 07:10 AM
89 CRX SI's Avatar
Default Re: b-20 v tec with what kinda head??????? (90CivicEX)
b16 head cause it is cheaper and easyer to find. i understand it also flows better on the b20z and b20b blocks.
Old Jun 6, 2002 | 08:50 AM
DJ KrunchyKracker's Avatar
Default Re: b-20 v tec with what kinda head??????? (89 CRX SI)
i would get a big head. with juicy lips.
Old Jun 6, 2002 | 09:20 AM
dohcsideSi's Avatar
Eric
i think you meant b18c1 higher comp (welded chambers). b16/b18c5 same head casting = same compression, if you are going to leave it stock get a newer b16 head the type R head is too hard to get and too expensive, stay away from early 1st gens and a/t heads, 12 year old valve springs aren't that reliable....if you are going to do a full build w/ p+p i would recomend a b18c1 (gsr) head it's dyno proven and will flow the same/more than a comparable b16 head..
and as dustin said..........have fun w/ the hydro tranny
[Modified by dohcsideSi, 6:22 PM 6/6/2002]
seatownda9
May 30, 2011 11:24 AM
hybrid_vtec
20
Apr 21, 2010 10:22 AM
804tuned
Engine Management and Tuning
Jul 21, 2009 12:11 PM
Kaan
Mar 27, 2003 01:49 PM
