mini meeh question
well i'm preparing to do the mini meeh swap this weekend...finally. and i have notice some things that i need to make sure of... my application is d15 bottom end with a d16y8 head.
1. do i have to remove the oil jet between cylinder 2 and 3?
2. vtec wiring....okay the single(green) wire connect to the solenoid goes to the vtec but the plug below it with two wires one black for the ground, but the other black with a blue strip, would that be the vtec pressure swtich?
3. are the wiring to the obd1 dizzy the same as the obd2 dizzy. planning on making my own jumper harness and just needed to know if the same colored wires are the same for the obd1 and obd2, so i can just match the wires up....
any info would be useful thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">1. yes
2. yes
3. yes</TD></TR></TABLE>
2. yes
boosh
Jul 16, 2003 02:30 AM
