I need help changing my tranny fluid...
Old Jun 21, 2007 | 01:33 PM
UrbanEh's Avatar
Default I need help changing my tranny fluid...
I am currently going through and doing some stufff to the motor while I have it out of the car. I was cleaning up the tranny yesterday and when I tipped it a small amount of fluid came out of the holes where the spindles go in. I figured I would need to replace that, then decided to just drain and refill the whole thing since it hasn't been done in a couple of year, at least.
I have the tranny (jdm M2B4) off of the motor. I am looking at what I belive to be the drain plug, the only bolt on the bottom of the housing.
Also, where do you put new fluid in, and how much. Any help would be much appreciated.
Old Jun 21, 2007 | 01:55 PM
nonvteclude's Avatar
Default Re: I need help changing my tranny fluid... (UrbanEh)
the drain plug will be a round bolt the a 3/8 drive opening to put a wrench in. i always filled mine from the vss but the actual fill plug is behind the axle on the passenger side
Old Jun 21, 2007 | 01:58 PM
UrbanEh's Avatar
Default Re: I need help changing my tranny fluid... (nonvteclude)
That is what I wanted to hear! How much fluid should I put in? Thanks
Old Jun 21, 2007 | 02:08 PM
E-Money's Avatar
until it squirts out the fill hole, usually almost two whole containers of Honda MTF
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
eg_gsr11
16
Feb 5, 2006 10:22 PM
4doorLX
Oct 2, 2002 10:55 AM
pelotudo
Jul 21, 2002 02:33 AM
96Prelord
Jun 5, 2002 07:21 PM
