tire pressure?
I have a 00 SI and the stock tires size is 195/55r-15, when i bought my car it was already lowered and had 195/50r-15 tires. recently i changed all four tires because they were worn very bad on the insides. I took the car to get balanced and the guy at first told me that i should inflate the tire's PSI to 43psi instead of the recommended 35 in front and 33 in rear by Honda. when he finished aligning the tires said the toe was bad so he fixed it. my question is should i still run 43psi, or go back to stock? my tires are YOKOHAMA AVS ES100 and on the tire it says the max psi should be 44 psi. isn't that bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">43 psi? Wow.
what does the side of your tire say?</TD></TR></TABLE>
All my Fuzion ZRi tires run at 42psi ... any less and they're too sloshy.
The 35F/33R is for stock tires at 175/65/13 (I believe that's the stock size for a CX).
I'd run your tires around 40-41 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Really? That's crazy, I think most passenger tires are 30-35 psi.
Most are but you can run them at whatever pressure you'd like, within reason. I run about 40 for the sake of MPG. Over-inflating your tires won't affect your handling as adversely as under-inflating them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ttk3 »</TD></TR><TR><TD CLASS="quote">
Most are but you can run them at whatever pressure you'd like, within reason. I run about 40 for the sake of MPG. Over-inflating your tires won't affect your handling as adversely as under-inflating them.</TD></TR></TABLE>
100% accurate
100% accurate
I prefer 40+ for the heck of it. People don't do everything the way "honda wants us to". Honda recommends 5w30 but some people use 10w30... I think your fine with your PSI.
You can run up to the max sidewall pressure no problem. It will also help you get better gas mileage with more air in the tires. Car manufacturer's recommendations are more for comfort and nothing else. Hell, my tires max sidewall is 51psi. I run 40-45 all day every day with no problems whatsoever.
I just hope you didn't get another set of 195-50-15 again! Because they are the wrong size for your car!
Btw I run 40 all around and its fine. I do it for 2 reasons.
1. better gas mileage
2. for handling purposes
ladius
Nov 24, 2004 04:04 AM
RATEDR
Apr 10, 2002 08:43 AM
