what else could it be?
please i need this car fixed im moving and need to to start to drive it. i just got done rebuilding my motor and putting it back in and all it does is crank.so i tested for spark have no spark and checked the injector and no power to the injectors i was told grounds.so i found the thermo ground off i put it back on.got more out but no power and spark still.so i was told the coil is bad so i replaced the coil.still same thing.changed the cap and rotor,coil,tightend and cleaned all grounds,checked the fuel injection relay good what else could it be?
averyvm
Jun 22, 2007 07:12 AM
