crx rear wheel hub replacement
Old Jun 21, 2007 | 11:11 AM
altoid's Avatar
Default crx rear wheel hub replacement
Ok so I couldn't find that 32mm everyone talks about. I did find a 15/16" nut so i guess thats like 23-24mm, its on the rear side, of the assembly, also I found 4 10mm bolts holding on the dust shield and there are four torx bolts on the rear that look like they hold on the caliper bracket (didn't remove the torx don't have the proper size). This hub won't come off, is it just seized on? the thing spins fine, but when I tug and pull and beat I can't get it off. alrighty, thanks.
Old Jun 21, 2007 | 11:22 AM
abnaasefmb's Avatar
Default Re: crx rear wheel hub replacement (altoid)
drum right? turn down the adjuster stars, should come right off. you can also use long bolts through the hub in the two hole provided, or release the fluid from the wheel cylinder in the back. also search it's been covered a million times. a manual is also very helpful.
Old Jun 21, 2007 | 12:13 PM
altoid's Avatar
Default Re: crx rear wheel hub replacement (abnaasefmb)
no this is for the Si disc swap. I have the TAs off the car and I am trying to swap out the bearings before I mount them to my chassis. The search blows ***. you find me a half decent thread that says more than remove 32mm nut, pull out, replace whole assembly, and i'll read that instead of asking for help from people who've actually done the procedure.
Old Jun 21, 2007 | 12:39 PM
abnaasefmb's Avatar
oh, yeah not too many people mess with that. maybe you could take pics and do a write up. i'll pm you a link to the helms manny
Old Jun 21, 2007 | 01:25 PM
bmg123's Avatar
For the rears, the Honda dealer sells the bearings within the Hubs as one unit. So it is a lot easier than the fronts. No pressing involved, just remove and replace. I have done this on TAs with drums and it is super easy. I don't think TAs with discs could be that much different.
Old Jun 21, 2007 | 01:46 PM
crxgator's Avatar
Default Re: crx rear wheel hub replacement (bmg123)
exactly...it's pretty cut and dry...take off the hub nut cover, take off the nut, washer and pull off the wheel bearing/hub assembly and put a new one on...id also get a new washer, nut, and cap...
Old Jun 21, 2007 | 05:51 PM
altoid's Avatar
Default Re: crx rear wheel hub replacement (crxgator)
well the nut being the big one on the back side? if so I took that one off, and beat the shaft it screwed onto and it did not budge one bit...should I soak it in WD40 over night and see how that works?
Old Jun 21, 2007 | 06:14 PM
abnaasefmb's Avatar
if you down load the crx manny i pm you the link to, it's on page 12-23. you might need a gear puller.
Old Jun 21, 2007 | 06:33 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altoid &raquo;</TD></TR><TR><TD CLASS="quote">well the nut being the big one on the back side? if so I took that one off, and beat the shaft it screwed onto and it did not budge one bit...should I soak it in WD40 over night and see how that works?</TD></TR></TABLE>
dude, what are you trying to remove? this is all from the front side...
Old Jun 21, 2007 | 06:35 PM
crxgator's Avatar
that's all from the front...
Old Jun 21, 2007 | 07:27 PM
altoid's Avatar
well hot damn....i should've removed the hub unit cap...apparently underneath the hub unit cap is a 22mm nut which allows for the removal of the hub assembly...i suppose i'll do that tomorrow. Though I did try to remove the hub unit cap today with a flathead screwdriver, didn't budge, tomorrow i'll try to some channel locks. I guess i'll take pics for everyone, maybe even do a video that way its pretty clear whats going on.
Old Jun 21, 2007 | 07:33 PM
Hiii Im TYLER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altoid &raquo;</TD></TR><TR><TD CLASS="quote">well hot damn....i should've removed the hub unit cap...apparently underneath the hub unit cap is a 22mm nut which allows for the removal of the hub assembly...i suppose i'll do that tomorrow. Though I did try to remove the hub unit cap today with a flathead screwdriver, didn't budge, tomorrow i'll try to some channel locks. I guess i'll take pics for everyone, maybe even do a video that way its pretty clear whats going on.</TD></TR></TABLE>
ahhh yes. VIDEO!
welcome to the 20th centry. Pictures are SO 1990's!
Mr.Speed
Jun 15, 2010 03:37 PM
xLaziestLa0b0ix
Honda Civic (2001 - 2005)
Oct 29, 2009 02:49 PM
SIRIUS
Aug 21, 2007 11:15 AM
JJ's civic
21
Aug 30, 2006 02:18 PM
typeeg
Feb 13, 2005 06:27 AM
