HOW DID THIS HAPPENED?
sorry about the cabs, my kboard is always in cabs 'cause of work, didn't pay attention...
I haven't taken out the piston yet...the top looks ok and the visible cyl walls look good too....2nd piston from right to left on pic, sorry i needn't take a closer pic...thank you.
I'd guess it was a power adder gone wrong (nitrous?), but it's hard to say. Could also be a clogged injector on that cylinder making it super lean? Anyway, if the seat is not too hosed you can probably just replace the valve. At least F-series are cheap and plentiful. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 »</TD></TR><TR><TD CLASS="quote">during racing. i did that to a few of my valves. trying to shift from 3rd to 4th at wot. went into 2nd.</TD></TR></TABLE>
Yea, but then all of the valves should have been FUBARed. This is only isolated to one particular cylinder.
thank you everyone for ur replies...i forgot to check the timing marks before removing the head. The cam gear is not adjustable..I forgot to mention this is the F22A1 SOHC motor...the machine shop where i took the head 2day said to check the piston rings cuz it's not firing(if those 2 valves are not sealing there is no compression, no firing right?) u think i should go ahead and remove the piston for inspection anyways...it's a little more work but i dun know how this happened and how far it goes right? Thanx....
no nos that I know of and no mods on the car, plain stock...the car has 124k miles...the shop said it would cost me $126 to replace the (2) valves, clean, resurface, inspect, and set back to spec...
xxi2icexx
Feb 2, 2011 06:23 AM
Gummiej
Jul 2, 2006 07:42 PM
