Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
flashing "main't required"
Old Jun 21, 2007 | 10:15 AM
sloem2's Avatar
Default flashing "main't required"
it only shows up when i turn off and on my car.. it goes away ounce i put it in drive??
Old Jun 21, 2007 | 10:31 AM
Curiouz_G's Avatar
in a while, the light will stay on. once it stays on, that means your car will self destruct Better go look in the FAQ @ the top of the page to find out how to prevent this from happening
Old Jun 21, 2007 | 10:36 AM
sujak's Avatar
better remove that titanium wing, the car weight distribution sensors re-learned themselves with all that downforce. so when you turn the car on there isn't all that weight so you get the "main't required" but once you start moving the downforce causes the weight to increase on the sensor and since it relearned it thinks that is normal while being stopped is wrong
Old Jun 21, 2007 | 11:44 AM
Curiouz_G's Avatar
sujak, im looking at your sig and those are some pretty sick numbers if theyre for a d17 props to you
Old Jun 21, 2007 | 12:18 PM
InanimateCarbonRod's Avatar
Default Re: flashing "main't required" (sloem2)
That's funny. When I would have this it only occoured when I turned the car on. When I turn the car off nothing lights up (as it should be).
ef-aay-cueeeeeee
Azcheron
Honda S2000
17
Aug 26, 2006 05:16 PM
mykcuz
Honda S2000
Aug 18, 2006 07:47 AM
racer_X_123
Mar 1, 2006 01:45 PM
D.CACO
52
May 8, 2004 10:46 AM
