Transmission
Old Jun 21, 2007 | 08:51 AM
rockenuptown's Avatar
Default Transmission
I want to know how many gears are on a d15b2 transmission honda civic lx 1988
Old Jun 21, 2007 | 09:07 AM
jlicrx's Avatar
Default Re: Transmission (rockenuptown)
manual transmission = 5 speed
automatic transmission = 4 speed
Old Jun 21, 2007 | 09:16 AM
Default Re: Transmission (jlicrx)
alright thanks im upgrading to a 5 speed automatic transmission from a 1992 honda civic lx d15b7 engine will that fit my d15b2 engine
Old Jun 21, 2007 | 09:20 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockenuptown &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks im upgrading to a 5 speed automatic transmission from a 1992 honda civic lx d15b7 engine will that fit my d15b2 engine</TD></TR></TABLE>
It will bolt onto your engine, but the bolt locations for the transmission mount are different, so it will not be a direct drop-in.
Old Jun 21, 2007 | 09:23 AM
Default Re: Transmission (wiZCo)
ill just modify it to work im pretty sure it will i need a higher top speed can you make it a longer ratio in the gears
Old Jun 21, 2007 | 11:02 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Yes you can mix and match gears, but I quite highly doubt you'll need more top end.
Old Jun 22, 2007 | 07:25 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Transmission (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can mix and match gears, but I quite highly doubt you'll need more top end.</TD></TR></TABLE>
With a manual transmission you can, he's swapping automatics. OP, it's not worth the headache to swap one for the other, but good luck anyways.
eg6ryder
Jan 29, 2006 07:23 PM
JMU R1
Jan 29, 2006 05:12 PM
benjy_b
Dec 19, 2005 01:37 PM
Engn
Acura NSX
Jan 31, 2005 11:58 PM
tinamina
Apr 9, 2004 05:00 PM
