itr swaybar bushing q'
Old Jun 5, 2002 | 09:14 PM
gsxr's Avatar
Default itr swaybar bushing q'
should i use the stock bushings or buy a set of polyurethane ?
Old Jun 6, 2002 | 04:59 AM
BSQ's Avatar
BSQ
Default Re: itr swaybar bushing q' (gsxr)
I would personally recommend using the Type-R swaybar bushing and bushing brackets instead of aftermarket polyurethane bushings. The reason that I say this is because the polyurethane bushings required frequent lubrication to prevent squeaking. Also the Type-R bushings are 5X stiffer than the stock bushings, which is comparable to polyurethane bushings. So you really will not gain anything by using the polyurethane bushings.
Old Jun 6, 2002 | 11:20 AM
ndustryalGSR's Avatar
Default Re: itr swaybar bushing q' (BSQ)
I heard a trick a while back to help prevent the need for frequent lubrication. Before installing the poly bushing, you can wrap the area of bar that contacts the bushing with teflon tape. Supposedly, this should ward off squeaking, indefinitely.
I'm sure the ITR stock bushings are more than adequate, though, as Bret mentioned.
Old Jun 6, 2002 | 11:24 AM
ragejed's Avatar
Default Re: itr swaybar bushing q' (ndustryalGSR)
does this mean all poly bishings need oiling???
Old Jun 6, 2002 | 11:36 AM
gsxr's Avatar
Default Re: itr swaybar bushing q' (ragejed)
thanks
Old Jun 6, 2002 | 12:38 PM
BROOD's Avatar
I also agree with using the ITR bushings and brackets.
But I have also used the teflon tape trick on Ploy bushings. It worked alright I guess.
[Modified by SLPR, 1:39 PM 6/6/2002]
Old Jun 6, 2002 | 02:59 PM
Only the ones that squeak.
Old Jun 7, 2002 | 02:46 AM
ragejed's Avatar
I read that the new Hyperflex ones done need any oiling. THis True?
Old Oct 22, 2002 | 07:18 PM
IC x Prince's Avatar
New User
I know this is an old post, but should I get the stock end link bushings aswell?
Old Oct 22, 2002 | 09:48 PM
Volcom's Avatar
Default Re: itr swaybar bushing q' (UltraGSR)
I have a question about the rear swaybar. I have the ITR rear bar and the bracket or whatever the endlinks connect to is not very sturdy. It looks weak and when you move it around with your hands, it moves very easily. I don't know much about suspensions but is there any reason to put something thicker in its place? I need to take a picture to discribe what I'm talking about but it's dark
Thanks
Aaron
Old Oct 23, 2002 | 11:27 AM
Volcom's Avatar
Default Re: itr swaybar bushing q' (Volcom)
Anyone?
Old Oct 23, 2002 | 12:06 PM
BSQ's Avatar
BSQ
Anyone?
You said "the bracket or whatever the endlinks connect to is not very sturdy. It looks weak and when you move it around with your hands, it moves very easily. I don't know much about suspensions but is there any reason to put something thicker in its place?"
I would be glad to help you out, but I'm not really sure what part you are referring to.
Old Oct 23, 2002 | 01:15 PM
Mr.Rab's Avatar
Anyone?
Take a pic, but I think I know what you are talking about.
Old Oct 23, 2002 | 02:03 PM
Weston's Avatar
Are you talking about the end links themselves? I noticed that they seem kind of flimsy.
Old Oct 23, 2002 | 08:20 PM
Volcom's Avatar
Default Re: itr swaybar bushing q' (Weston)
Here's a bad picture of what I was trying to say. I circled it in red. It connects the swaybar to the LCA.
Thanks brett and anyone else that know whats up!
Aaron
Old Oct 23, 2002 | 09:21 PM
ALF's Avatar
ALF
Did you reuse your old ones? I have high mileage like yours and I opted to change out the endlink bushings on mine for new stock ones. When I removed my old swaybar, the old ones were cracked and extremely worn.
Old Oct 23, 2002 | 09:24 PM
Volcom's Avatar
Default Re: itr swaybar bushing q' (ALF)
yea, i used new bushings. It just seems like that piece in red is kinda weak compared to the ITR rear bar and the LCA. Would it be better to have something stiffer in its place? Just curious?
Aaron
Old Oct 23, 2002 | 10:45 PM
Mr.Rab's Avatar
Yeah I think I committed on that when we were installing my bar. I was like what's up with this flemsy POS. I'll replace mine when it breaks.
Old Oct 24, 2002 | 08:11 AM
Aaron M's Avatar
Default Re: itr swaybar bushing q' (Dr. RAB01GSR)
i havent done this mod yet, but would it even matter if its flimsy, since all its doing is pushing down on the LCA?
Old Oct 24, 2002 | 08:22 AM
New User
Default Re: itr swaybar bushing q' (SilverB18C1)
I don't think so either, but if they do break those things are like 5 dollar i think. I am doing mine this weekend.
Old Oct 24, 2002 | 10:23 AM
BSQ's Avatar
BSQ
The Type-R and the rest of the G3 Integras use the same endlink. The only difference is that the Type-R small endlink bushing at the bottom is stiffer than the non-Type-R Integra endlink bushing. I have tried both endlinks on my car and I didn't notice a difference. So I recommend just using the stock endlinks...they are fine .
Old Oct 24, 2002 | 11:43 AM
New User
could I reuse my stock endlinks? or should I get new ones?
Old Oct 24, 2002 | 02:17 PM
gsxr's Avatar
huh?
Old Oct 24, 2002 | 03:09 PM
New User
I meant the endlink bushings. could I reuse those?
Old Oct 25, 2002 | 12:04 AM
BSQ's Avatar
BSQ
I would highly recommend buying new swaybar endlink bushings.
