Which is the better OBD2 ECU to run for LS/VTEC?
Old Jun 20, 2007 | 08:07 PM
Vero's Avatar
Default Which is the better OBD2 ECU to run for LS/VTEC?
Would it be better to run a P2T (99-00 Si) ECU, or would a P73 from a 96-99 ITR work better?
This would only be for emissions purposes and would be used for short periods at at a time.
Is any one ECU better depending on the compression reached?
Old Jun 20, 2007 | 08:20 PM
egsleepercivic's Avatar
I would say type r, because it is a 1.8, and so is your lsv
Old Jun 21, 2007 | 10:48 AM
Vero's Avatar
Default Re: (egsleepercivic)
Do you know if the USDM and the JDM ITR ECUs are the same as far as emissions output?
Old Jun 21, 2007 | 01:56 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (Vero)
i would say a gsr because the lesser compression, i guess it all depends on the cams and compression your running....
9.1:1-10.5:1 go with gsr, anything higher go with type r
Old Jun 21, 2007 | 01:57 PM
I'm not sure, but I believe the JDM ecus do not look for the same sensors as USDM ecus, and may not be compatible with emissions testing. If you have to do a sniffer test you could probaly pass, but if they plug into your ecu I think you are toast
Old Jun 22, 2007 | 12:28 AM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure, but I believe the JDM ecus do not look for the same sensors as USDM ecus, and may not be compatible with emissions testing. If you have to do a sniffer test you could probaly pass, but if they plug into your ecu I think you are toast</TD></TR></TABLE>
thats true!
Old Jun 22, 2007 | 04:27 AM
Vero's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">i would say a gsr because the lesser compression, i guess it all depends on the cams and compression your running....
9.1:1-10.5:1 go with gsr, anything higher go with type r</TD></TR></TABLE>
I am using a b16 head, wont a GSR ECU check for IACV/butterflies?
I spoke with Katman, he confirmed this to be true. My state uses a scan tool to check on OBD2 vehicles.
Old Jun 22, 2007 | 07:29 AM
Vero's Avatar
Default Re: (Vero)
anyone know if the GSR ECU will work on a b16/b18b LS/VTEC?
Old Jun 22, 2007 | 08:17 AM
yeah it will work, won't get a code for not having the IAB hooked up
-__-
Sep 16, 2010 05:14 PM
kadidle
Engine Management and Tuning
Jan 3, 2009 07:32 AM
VTECcnIT
Feb 6, 2006 01:57 PM
DXsiRII
Oct 1, 2003 07:31 PM
silvershiny-ek
May 15, 2003 08:00 AM
