catalytic converter to cat-back flange bolts (welded?)
Old Jun 20, 2007 | 06:25 PM
IntGSR's Avatar
Default catalytic converter to cat-back flange bolts (welded?)
How do I remove these three bolts from the flange? It seems like they are welded to the flange. I was in process of installing catback and could not separate the stock catback. I ended up using dremel and hack saw to cut them off. Now I am stuck with cut off bolts on the flange.
Old Jun 20, 2007 | 07:04 PM
doood's Avatar
been there done that
Default Re: catalytic converter to cat-back flange bolts (IntGSR)
they like to get really rusted. lots of wd40 or pb blaster does wonders.
Old Jun 25, 2007 | 07:49 AM
IntGSR's Avatar
Default Re: catalytic converter to cat-back flange bolts (doood)
Finally, I got that DAMN bolts off the flange. It took some heating with propane torch and lots of PB blaster, then bit of pounding with hammer. I used cobalt bit to drill one of the bolts since I cut off the head and thread. Anyway, apexi WS II is on the car now
20CiviC02Si
Mar 30, 2015 08:03 PM
biada2.5
Jan 31, 2006 10:01 PM
civiccoupe94
34
Nov 17, 2005 08:15 AM
oMek
May 6, 2004 01:06 PM
swlabhot
Apr 29, 2003 08:19 AM
