fan switch
when i did my motor swap my girlfriends step dad tore off my fan switch, I'm thinking about creating a switch so i can turn it on when i feel i need it, ghetto I know but idk how hard it is to replace a fan switch. so basically where can i grab a power supply from?
you just wire it up to a relay, fused power goes into the relay, Another wire to the fan, one goes to switched power(so it only comes on when the car is on) and the last is a ground which goes into the thermo switch then back out and grounded to the frame. very easy, the relay is usually marked on top as to what goes to what. If a general use 12v relay 30 goes to the fan, 87 to power(with a fuse inline a 15amp should be good), 85 to switched power(+) and 86 to thermo switch then to ground from other pin on thermo switch. Im pretty sure this is right just google 12 relay. Im sure you can figure it out
you just get a switch..and two wires, put one from the battery to the switch, and one from the power wire on the fan to the other side of the switch..you dont have to do anything with the relay..
i just dont wanna ware out my fan with battery power ya know, and the fan switch on the back of the block of my b16 the plastic containing the connector is what broke off, no fluid leaks just scared because the warm weather is here and i wanna be able to cool it down
o and where exactly would i be running the wire from, cause Thats the part I'm not 100% about yes relay blah, but where exactly am i drawing the power from, the fuse box maybe?
you should buy a new coolant temp/fan switch. really
in the mean time, you can easily tap into one of the wires going into the coolant temp switch (Yellow/Green) which should show 12V+ with the key in the ignition. Tap into it and run your new wire to a switch inside the cabin. The other side of the switch run to a good ground. done
When you actually replace the fan switch (which you should) you will still have the option to turn on the fan with your switch.
well i know i was just thinking an unknown amount of volts going to the fan straight from the battery might short it, I'm not sure on how many volts it needs or would get, ya know?
in my crx with a sohc zc all i did was take the two wires at the fan itself and ground the negative to the battery with the U connector thing and then took the power wire to the fuse box under the dash and found something with power and hooked it up to a switch in the little coin tray to the left of the steering column.
It looks clean and works all the time. But seriously i live in the so cal desert and i rarely use the fan, only when at a dead stop for a few minutes does it get hot.
ya I heard that i just wanna have a back up in case I'm stuck in traffic and it starts to get a lil warm, plus I'm doing my first big run this weekend to the desert of eastern washington so I wanted to make sure i had ti in before i left.
Why do people want to ghetto rig these things? It only takes an hour or so do do it properly with a relay, and as someone posted earlier you dont want to run wires straight to the switch without a relay, the switch is not meant for hight current draw and will get fried. It is meant to ground the relay circuit. Also if wired straight to the switch this will keep your fan on when the car is off
i dont have anything connected to my switch in the back of the block. It is all bypassed and i just controll with a little on/off switch when the fan is on or off.
SteelcityLude
Aug 27, 2011 02:46 PM
