eg b16 swap a/c problem
Old Jun 20, 2007 | 01:44 PM
blackcrx16's Avatar
Default eg b16 swap a/c problem
hello all, i have a 1992 civic with a swapped b16. it all runs good so i wanted a/c. since i had the psr bracket i put a gsr compressor in the car and vaccumed it down and charged it with 2 and a half cans of 12oz r134a. when i turn on the system on 4, it dosnt blow cold and the compressor will trip in for a few seconds and then out for about 7 or so seconds the back in again. when i put the a/c on 1 the compressor will trip out and the air will get colder but not as cold as i would expect. i asked some people what to do and they just said put the single cam compressor in but no one ever tells me why. i just figure that a compressor is a compressor whats the problem. anyway. any help will be much appreciated due to the fact that its 100 degrees and raining in florida right now. lol
Old Jun 20, 2007 | 03:38 PM
kevin0405's Avatar
Default Re: eg b16 swap a/c problem (blackcrx16)
dont have an idea of the problem of your compressor, but since it is a 92 did your retrofit the r12 to r134a? if you put 2 and a half cans of 12oz that would equal 30oz. normal is between 17.6 to 19.4 oz. i have heard if there is to much freon it will not cool better.
Old Jun 20, 2007 | 04:00 PM
crx378's Avatar
Default Re: eg b16 swap a/c problem (kevin0405)
to much is actually worse
Old Jun 20, 2007 | 04:05 PM
kevin0405's Avatar
Default Re: eg b16 swap a/c problem (crx378)
thats what i meant, it will not cool as good with too much freon
Old Jun 20, 2007 | 04:26 PM
IronmaN's Avatar
if the system holds vacuum and there isn't any leaks i would suggest that you evacuate the system, put the correct amount of charge in and then check it before you start swapping compressors etc.
Old Jun 20, 2007 | 04:39 PM
94eh2's Avatar
Default Re: eg b16 swap a/c problem (IronmaN)
you shouldve kept your d series compressor if you had one and couldve an the delsol bracket...
Old Jun 20, 2007 | 07:33 PM
blackcrx16's Avatar
Default Re: eg b16 swap a/c problem (305accord)
i understand all this but the probelm i have is that the compressor wont run long enough to cool , it only runs for like 10 seconds max and then trips out and then about 5-7 seconds later it kicks back in and then out for another 10 sec. what could cause this? does the gsr compressor pump more freon than the single cam compressor?
i have the single cam compressor and all just missing the condensor line. what should i do?
Old Jun 20, 2007 | 07:40 PM
crx378's Avatar
with to much freon in it I don't think it will run longer than ten seconds safety feature I believe
Old Jun 20, 2007 | 07:43 PM
crazyguy's Avatar
do u use a brand new dryer/receiver.a little silver can that looks like a bullet ?
Old Jun 21, 2007 | 01:49 PM
blackcrx16's Avatar
Default Re: eg b16 swap a/c problem (crazyguy)
no i didnt use a brand new one, i used a old one a friend gave me out of his car. his a/c blew ice and he took it apart to change everything( why i have no idea) my old one was clogged up with what looked like mud. black oil and dirt? anywho what do you think?
Old Jun 21, 2007 | 01:54 PM
94civic18's Avatar
quick fix..... move to colorado (we dont have humidity) :-D
good luck with the diagnosis
AGHondaCivic
May 27, 2017 03:16 PM
EM2Civic
Aug 20, 2010 12:40 PM
bugzpimpin
17
Oct 19, 2005 01:32 PM
globlctzn
Apr 1, 2003 11:18 AM
