OEM hubcaps, wrapped manifold, projector headlights, injectors, wire, coil, etc...
Ok, decided today I was going to clean out the garage and get rid of some things I no longer need. So, here goes.
OEM Civic hubcaps. Nuf said. SOLD!!
DEI heat wrapped exhaust manifold and downpipe for a D16Y8. $50 shipped.
Projector Headlights. Come with Sylvania Silverstar highs and lows. $70 shipped.
Only reason they look wet is because I cleaned them. It will dry out.
Stock axles off a D16Y8. Not sure of mileage. Look decent. $50 shipped/both.
Remanufactured stock injectors off a D16Y8. MAYBE 2000 miles. $60 for all 4.
1/0 gauge red and black cable. Maybe 15' black and 20' red. Perfect for battery relocation. Thats what I used it for. $40 shipped for all of it.
25' Rubber air hose. Top quality. New! $25 shipped.
50' Rubber air hose. Used. Still in new condition. $40 shipped.
50' Rubber air hose. Older. Still in good shape. $30 shipped.
MSD Blaster 2 ignition coil. Used for maybe 2 weeks. $30 shipped.
New garage exhaust tubing. Perfect for working on your car in the winter without opening the garage door. Comes with:
2 each - 4' x 2-1/2" Hose
1 each - 6' x 2-1/2" Hose
1 each - 2-1/2" Rubber "Y" Connector
2 each - Straight tailpipe adapter, hook and chain.
1 each - Splice Connector*
Also the door port adapter so you have somewhere for the hose to go outside. Kit and door port would cost about $150. I'll let it go for $90 shipped.
Modified by ericschimmel at 10:13 AM 6/22/2007
Threads
Oct 19, 2006 10:20 PM
ebp 99 si
Sep 3, 2003 03:55 PM
for a homie.
