problem with revving
Old Jun 20, 2007 | 11:03 AM
93formula's Avatar
Default problem with revving
i got a problem while revving, when at a steady throttle position the car feels like it hits a rev limiter, yet if i put more pressure on the throttle it goes away and i can floor the car just fine.
the odd thing is when i reverse the yellow and green wire at the tps the problem goes away completley except ofcourse when i go wot, then it bogs.
i tried a brand new distributor, another used throttle body and there are no other codes except for 14, iacv. voltage between the two tps wires are 5v. also tried another ecu, same thing.
the car was originally a dpfi, converted to mpfi, car ran fine for one day, problem started the next day.
whats wrong do i need to try another tps/throttle body?
any help appreciated.
Old Jun 20, 2007 | 11:46 AM
93formula's Avatar
Default Re: problem with revving (93formula)
also the voltage from the red wire at closed throttle is .75v is that a bit high?. and when i have the throttle on a steady angle and measure the voltage it does not flucuate.
Old Jun 20, 2007 | 12:25 PM
93formula's Avatar
also at the ecu pin c7 red/white wire is getting a constant 2.8v regardless of throttle position and the car being on or off, could this be my problem?
Old Jun 20, 2007 | 12:37 PM
93formula's Avatar
my bad i was measuring the wrong pin, the pin c7 red/blue wire does have the same .75 v the tps sends out and goes up to the 5v whent he throttle is pressed.
Old Jun 20, 2007 | 02:49 PM
93formula's Avatar
can this be a fueling issue? because when i reverse the tps wiring it thinks its wot at idle and so on. but i just dont understand why it runs perfect when reversed.
UKintegra
Jun 8, 2011 12:32 PM
92prelude23
Jan 26, 2009 05:43 PM
boostcrx89
Jan 6, 2008 07:54 PM
Des9255
Oct 24, 2005 09:58 PM
WAFFLES
Apr 25, 2003 01:42 PM
