2nd and 3rd-Tranny
Old Jun 20, 2007 | 09:25 AM
BlackLudeSR's Avatar
Default 2nd and 3rd-Tranny
hey
i jus got my clutch replaced
but i found out that there is a problem wit the tranny.
the gears are perfect in 1st, 4th, 5th
but wen i down shift to 2, i hear a grind
and my gear will shift perfect to 3 because of the new clutch but as soon as i let go of the clutch..the gear slips back out or itll start to grind
HELP
Old Jun 20, 2007 | 02:17 PM
E-Money's Avatar
Default Re: 2nd and 3rd-Tranny (BlackLudeSR)
did you break in the clutch?
Old Jun 20, 2007 | 02:27 PM
phateless's Avatar
Tranny fluid is the obvious first step. Check your clutch master fluid as well. Do some investigating... Could be a syncro.
Do the tranny fluid first, and report back.
HONDA MTF FROM THE DEALERSHIP ONLY!!!!
Old Jun 20, 2007 | 03:17 PM
jdmlude5
Guest
Posts: n/a
Default Re: (phateless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote">Tranny fluid is the obvious first step. Check your clutch master fluid as well. Do some investigating... Could be a syncro.
HONDA MTF FROM THE DEALERSHIP ONLY!!!!</TD></TR></TABLE>
x2 i would be leaning more towards the syncro.
Old Jun 21, 2007 | 01:50 PM
phateless's Avatar
Another thought... are you rev-matching your downshifts? Try double-clutching, and see if the grind goes away. If it does, it's probably your syncro. If you are good at double clutching, who cares if your syncro is out. Drive it anyway.
But change that damn tranny fluid!!
DC5Danny
Jan 21, 2008 08:36 AM
phoshizzle88
May 17, 2006 10:39 PM
WingDC2R
Dec 11, 2005 08:21 PM
andrewasf77
Jun 19, 2003 07:32 PM
1fastdc2
Nov 4, 2002 02:09 AM
