just need clarification/ itr rear seats
Old Jun 20, 2007 | 01:36 AM
mikeycivic's Avatar
Default just need clarification/ itr rear seats
I have a 00 coupe that I want matching itr rear seats for. I found that the 2 door itr seats will not fit but the 4 doors will. Is it true that I need the 2 door itr bottoms with the 4 door itr tops, or can I use the full 4 door itr set for the top and bottom?
Old Jun 20, 2007 | 03:41 AM
nathanong87's Avatar
Default Re: just need clarification/ itr rear seats (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 00 coupe that I want matching itr rear seats for. I found that the 2 door itr seats will not fit but the 4 doors will. Is it true that I need the 2 door itr bottoms with the 4 door itr tops, or can I use the full 4 door itr set for the top and bottom?</TD></TR></TABLE>
i think it's the other way around. db8 bottoms and dc2 back, if i'm not mistaken.
Old Jun 20, 2007 | 03:43 AM
mikeycivic's Avatar
Default Re: just need clarification/ itr rear seats (nathanong87)
isnt the dc2 2 door? If so they wont work
Old Jun 20, 2007 | 03:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">isnt the dc2 2 door? If so they wont work</TD></TR></TABLE>
yes. dc2 = coupe. i don't know whut ur asking "won't work"
Old Jun 20, 2007 | 03:48 AM
mikeycivic's Avatar
the itr seats from a dc2 will NOT fit in a 00 civic coupe, I need the db8 itr's. Will the db8 bottoms fit or do I need the bottoms from a dc2????
and the dc2 is not a coupe its a hatchback, hence the reason why the itr's from a dc2 wont fit in a civic coupe!
Old Jun 20, 2007 | 03:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">the itr seats from a dc2 will NOT fit in a 00 civic coupe, I need the db8 itr's. Will the db8 bottoms fit or do I need the bottoms from a dc2????</TD></TR></TABLE>
like i stated before, i'm fairly sure that you will need the bottoms from the db8 and the backing from the dc2.
have u tried to fit the dc2 seats in? why do u say they won't work. the db8 bottoms will minimize the gap between the backing and the sides (at least in the EG)
Old Jun 20, 2007 | 03:55 AM
mikeycivic's Avatar
the dc2's are too small in every sense of the word, I know I need the db8 backs, but I am not sure if I need the dc2 bottoms or the db8 bottoms,
Old Jun 20, 2007 | 04:06 AM
well db8 bottoms are whut u need becuase they are wider and won't leave gaps.... and the backing is also one piece and wider. u may have to do some hacking of the foam, but yes the DB8 rear is wider larger whutever u want to call it.
Old Jun 20, 2007 | 04:09 AM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 &raquo;</TD></TR><TR><TD CLASS="quote">well db8 bottoms are whut u need becuase they are wider and won't leave gaps.... and the backing is also one piece and wider. u may have to do some hacking of the foam, but yes the DB8 rear is wider larger whutever u want to call it.</TD></TR></TABLE>
well this is becoming way too much of a headache so resolve it all I am just going to get my stock seats re wrapped to match the fronts, = same price and less hassle
Old Jun 20, 2007 | 07:12 AM
RDix's Avatar
your gonna have to get your stock seats re-wrapped or your gonna have to cut up some db8 seats...i have a 2000 coupe as well, i've tried the dc2 itrs and the db8 itrs...mismatching them won't work either, these seats will only fit in eg's or ek hatches, they won't fit right into coupes...search on here a little bit, there have been people who have custom fitted some rears but it's a pain in the *** to do...good luck with the project though
Old Jun 20, 2007 | 07:19 AM
mikeycivic's Avatar
Default Re: just need clarification/ itr rear seats (RDix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RDix &raquo;</TD></TR><TR><TD CLASS="quote">your gonna have to get your stock seats re-wrapped or your gonna have to cut up some db8 seats...i have a 2000 coupe as well, i've tried the dc2 itrs and the db8 itrs...mismatching them won't work either, these seats will only fit in eg's or ek hatches, they won't fit right into coupes...search on here a little bit, there have been people who have custom fitted some rears but it's a pain in the *** to do...good luck with the project though </TD></TR></TABLE>
f all that, it'll be cheaper to just get mine re wrapped, you got pics?
Old Jun 20, 2007 | 07:35 AM
RDix's Avatar
yea just get yours re-wrapped...it'll look alot cleaner and you will save a little. I opted to just remove my rear seats and do a custom back seat to truck setup so i dont have any pics of the rear seats people have put in...your gonna have to search the archives
Old Jun 20, 2007 | 07:39 AM
enkeirp02's Avatar
What i did on my old coupe si, I was able to source the 4 door ITR rear seats. The back portion mounts fine, you just need to modify the brackets on the back of the seat in order to fit the civic. for the bottom portion you can just use one from the 2dr ITR since the 4 door itr bottom is quite wide.
This has been done by me personally, and it works. You already had a thread on this same topic.
https://honda-tech.com/zerothread?id=2013360
Old Jun 20, 2007 | 07:43 AM
RDix's Avatar
Default Re: just need clarification/ itr rear seats (enkeirp02)
got pics??
Old Jun 20, 2007 | 07:46 AM
enkeirp02's Avatar
It was quite a while ago, don't have pics (direct shots of the seats). Don't even have the car anymore.
Old Jun 20, 2007 | 07:50 AM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enkeirp02 &raquo;</TD></TR><TR><TD CLASS="quote">What i did on my old coupe si, I was able to source the 4 door ITR rear seats. The back portion mounts fine, you just need to modify the brackets on the back of the seat in order to fit the civic. for the bottom portion you can just use one from the 2dr ITR since the 4 door itr bottom is quite wide.
https://honda-tech.com/zerothread?id=2013360</TD></TR></TABLE>
correct but I just wanted to be 100% sure before started hunting this stuff down but I am just going to get my stock seats custom wrapped and be done with it
KINTA94
Mar 5, 2010 07:08 PM
mikeycivic
Jun 20, 2007 05:06 AM
simplsi
Apr 26, 2007 09:00 PM
colinproctor
30
Jun 12, 2005 05:32 PM
