Honda S2000 Honda S2000
broken differential...some advice please
Old Jun 19, 2007 | 09:01 PM
ReddotsS2K's Avatar
Default broken differential...some advice please
well for the past week i have been experiencing a slight vibration whenever i accelerate and i hope that it was related to this. i downshifted into second gear from third going about 35 or 40. i didnt match my rev . has anyone seen anything like this...is it normal? this is what happened...
anyways...i need help on where to find a new one. i looked on ebay and googled but i just wana make sure i go to the right place and get the best for the money.
Old Jun 19, 2007 | 09:11 PM
CrisEK's Avatar
What's done to the car? They do make aftermarket diff housings that are built stronger. But when my buddy put one on his Comptech S/C S2k there was a pretty loud whine that was pretty annoying. I'll find out what diff housing he got, but I'm telling you, for some reason ever since he got that, that whine was present. He also craked the housing like you did, but it was S/C.
Modified by CrisEK at 11:51 PM 6/19/2007
Old Jun 19, 2007 | 09:12 PM
LAS2K's Avatar
Default Re: broken differential...some advice please (ReddotsS2K)
sheiiit!! wow never seen one crack all the way from end to end like that before...wow.
best bet is to find a used one from a junk'd s2k, or try s2ki.com.
upgrade to an ap2 diff while you're at it.
Old Jun 19, 2007 | 09:17 PM
ReddotsS2K's Avatar
Default Re: broken differential...some advice please (LAS2K)
haha the car is stock other than cold air intake and test pipe. i though it was pretty crazy myself. it also cracked the other part too a little bit.
would the ap2 diff bolt right up and is it the same gear still?
Old Jun 19, 2007 | 10:42 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
It happened because God hates you for using a test pipe
Old Jun 20, 2007 | 12:28 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">
would the ap2 diff bolt right up and is it the same gear still?</TD></TR></TABLE>
The AP2 rear end will fit, but you will have to use 04+ hex bolts between it and the propeller shaft.
Old Jun 20, 2007 | 05:35 AM
JDM knowledge's Avatar
Default Re: broken differential...some advice please (Mr. Projekt)
omg. 8k Clutch drops lately?
Old Jun 20, 2007 | 05:36 PM
WuWarrior's Avatar
I saw this before, almost exactly the same. The owner of that car did it TWICE! To be fair, he had a habit of showing off and doing drag launches.
I hope you don't, or atleast learn to go easy on the differential in the future.
Old Jun 21, 2007 | 10:23 AM
ReddotsS2K's Avatar
no i dont race or drag race the car. i think its pointless. i just popped the clutch to quick in a down shift i am still searching for a rear end. this sucks.
Old Jun 21, 2007 | 11:31 AM
LBBP R's Avatar
the big white mark on front of the differential makes me think that you hit something on the road...??? cuz, i never seem a diff crack going from front to rear..
Old Jun 21, 2007 | 12:01 PM
orangebarius's Avatar
Default Re: broken differential...some advice please (LBBP R)
there are currently 2 on ebay right now:
http://search.ebay.com/s2000-d...known
Old Jun 21, 2007 | 12:04 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBBP R &raquo;</TD></TR><TR><TD CLASS="quote">the big white mark on front of the differential makes me think that you hit something on the road...??? cuz, i never seem a diff crack going from front to rear..</TD></TR></TABLE>
Sounds right, but I don't see the white mark you're talking about. I only see a yellow threadlock dot, and a reflection of the camera's flash. Plus, it would have hit that cross bar first.
Old Jun 21, 2007 | 12:20 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
wow dude, thats a pretty serious crack...
Old Jun 21, 2007 | 05:22 PM
ReddotsS2K's Avatar
yeah well i have it pulled apart now. there is a lot more cracks and broken gears. i take some pictures.
Old Jun 21, 2007 | 09:00 PM
CrisEK's Avatar
check this, I found a rear diff on ebay.
http://cgi.ebay.com/ebaymotors...wItem
Old Jun 21, 2007 | 09:23 PM
WowOzYouRock's Avatar
Default Re: (CrisEK)
what were you thinking down shifting to second doing 40 MPH?
lemme guess, you were tryna slow down just by holding the clutch while making high speed cornering... then you decided to downshift to second gear and then you just drop the clutch... im a right?
when you down shift to second with that speed, let go the clutch slowly just like yer in the first gear... you have to let your clutch slip knowing the engine in low RPM...
you learn it hard way and it sucks...
get it fixed and remember what i said... ROFL
Old Jun 22, 2007 | 02:23 PM
S2KILLA's Avatar
Default Re: (WowOzYouRock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WowOzYouRock &raquo;</TD></TR><TR><TD CLASS="quote">what were you thinking down shifting to second doing 40 MPH?
get it fixed and remember what i said... ROFL </TD></TR></TABLE>
dude are you ****** serious??? downshifting into 2nd at 35-40 is nothing as long as he rev matched... even still, I dont think that his diff should have cracked like that, there might have been prior abuse and this was the last straw... yeah it was a dumb move but you dont have to be a dick about it...
Old Jun 22, 2007 | 02:57 PM
Default Re: (SupersonicBlueGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">
dude are you ****** serious??? downshifting into 2nd at 35-40 is nothing as long as he rev matched... even still, I dont think that his diff should have cracked like that, there might have been prior abuse and this was the last straw... yeah it was a dumb move but you dont have to be a dick about it...</TD></TR></TABLE>
ummm.. knowing that he said he didnt rev match....ahhh yeah ... LOL
you should go try it see what happens...
i was being a dick? ROFL ... did you see all the " " ??? its sarcasm...
mkthnxbye
Old Jun 22, 2007 | 02:59 PM
ohhh and remove my quote in yEr sig ... i didnt give you permission to post that... HAHAHAHAHAH
Old Jun 23, 2007 | 10:43 AM
ReddotsS2K's Avatar
actually that isnt what happened...i wish i had a good excuse but the truth is quite pathetic. I drove by two old people walking and and i wanted to pop into second and scare the **** out of them. test pipe + intake = loud **** . instead it made a huge "pop" and the wheels locked up and spun the car pretty rapidly. anyways i know it was stupid and im willing to take the abuse from eberyone
Old Jun 23, 2007 | 10:45 AM
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrisEK &raquo;</TD></TR><TR><TD CLASS="quote">check this, I found a rear diff on ebay.
http://cgi.ebay.com/ebaymotors...wItem</TD></TR></TABLE>
thanks bro im following it
Old Jun 24, 2007 | 01:30 PM
361 accord's Avatar
Default Re: (ReddotsS2K)
thats a bitch
OT: but what are you driving now?
Old Jun 24, 2007 | 02:07 PM
Default Re: (361 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord &raquo;</TD></TR><TR><TD CLASS="quote">
OT: but what are you driving now?</TD></TR></TABLE>
does it really matter or yEr just being nosy? ROFL
Old Jun 24, 2007 | 05:57 PM
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361 accord &raquo;</TD></TR><TR><TD CLASS="quote">thats a bitch
have an e36 but ironically it broke yesterday and started throwing coolant everywhere (havnt driven it in months) so i been driving my moms clk430 or cooper s until i can get a diff.
im going through s2k withdrawals here
DFW
Sep 13, 2007 07:59 AM
reebs
Aug 4, 2006 12:37 PM
EngineNoO9
Honda Motorcycles
39
Jul 30, 2006 06:06 PM
t o m
Apr 13, 2005 10:41 PM
CWTegRNo.160
Dec 26, 2004 11:46 PM
