car push starts but doesn't start with key?
Old Jun 19, 2007 | 07:46 PM
Timmyflys's Avatar
Default car push starts but doesn't start with key?
i have a 1992 civic hatchback with a ls swap and i can push start it but i it does not want to start with the key fuel pump primes everything good main relay good what could be the cause of this??? please heLP any input is appreciated thanks
Old Jun 19, 2007 | 07:52 PM
red ej's Avatar
Default Re: car push starts but doesn't start with key? (Timmyflys)
i would say the starter, just a wild guess
Old Jun 19, 2007 | 07:54 PM
Timmyflys's Avatar
Default Re: car push starts but doesn't start with key? (red ej)
checked starter starter is good
nething else?
Old Jun 19, 2007 | 07:55 PM
russlan44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red ej &raquo;</TD></TR><TR><TD CLASS="quote">i would say the starter, just a wild guess</TD></TR></TABLE>
x2 check the fuses also
Old Jun 19, 2007 | 07:56 PM
Timmyflys's Avatar
Default Re: car push starts but doesn't start with key? (russlan44)
what fuses could it be ?? ive checked em all
Old Jun 19, 2007 | 08:03 PM
951BRO's Avatar
did you check the power wire that runs direct to the starter?
Old Jun 19, 2007 | 08:04 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: car push starts but doesn't start with key? (951BRO)
battery could be low on charge
Old Jun 19, 2007 | 08:17 PM
truevietluv636's Avatar
Default Re: car push starts but doesn't start with key? (JJSpecTuning)
same thing with my friends car, the wires on the starter were not connected properly.
Old Jun 19, 2007 | 08:32 PM
egsleepercivic's Avatar
does it turn over at all when trying to start it with the key?
Old Jun 19, 2007 | 08:52 PM
chingpo05's Avatar
Default Re: (egsleepercivic)
bypass the clutch saftey switch
Old Jun 20, 2007 | 11:21 AM
Timmyflys's Avatar
Default Re: (chingpo05)
it has a brand new battery in it. ive checked the starter wires a million times. how do i bypass the clutch safety switch and what is that going to do for me?
Old Jun 20, 2007 | 11:26 AM
Timmyflys's Avatar
Default Re: (Timmyflys)
can someone give me some pictures of where the clutch safety switch is located
Old Jun 20, 2007 | 11:38 AM
civic j's Avatar
possibly a chipped master key.~!
Old Jun 20, 2007 | 11:46 AM
Timmyflys's Avatar
Default Re: (civic j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic j &raquo;</TD></TR><TR><TD CLASS="quote">possibly a chipped master key.~!</TD></TR></TABLE>
say what??
Old Jun 20, 2007 | 11:48 AM
WebWorks's Avatar
ignition?
WebWorks's Avatar
also, howd you test starter? Tapping it?
Old Jun 20, 2007 | 12:07 PM
civic j's Avatar
Default Re: (WebWorks)
red-black keys have a internal chip dont they
Old Jun 20, 2007 | 12:42 PM
there is a thin black wire that connects to the starter with a spade type connecter, make sure this wire is securely connected, if it is not it will not start with the key, I had this same situation with a friends 97ex, it would push start but it would not start with the key, the wire had come of we re attached the wire and it started fine
gl
Old Jun 20, 2007 | 12:45 PM
Timmyflys's Avatar
starter came off my buddys running gsr then took it too advance auto to see if it was any good and they said its good has to be something with the ignition bad or something. the guy i bought it from left it outside with no drivers side window for a few months could of the ignition got wet and something shorted out or something or that sort?
starter is off a 00 gsr that will work with a ls swap with b16 tranny correct?
Old Jun 20, 2007 | 12:47 PM
IIXtremeHansen's Avatar
yes ignition/starter wire, i see this all the time after i had mines F'ed up. i rewired and starts fine.
Old Jun 20, 2007 | 12:52 PM
kleanlscivic's Avatar
newer hondas have these but none of the 92-00 civics shoudl have them. i had the problem with the ls swap into my 99 civic. i had to run a ground wire to it and it has started fine ever since
Old Jun 21, 2007 | 11:35 AM
Timmyflys's Avatar
Default Re: (kleanlscivic)
is there a ground anywhere on the starter? theres the black and white wire to the starter and then the positive cable on there is there suppose to be a ground or something on there?
Old Jun 21, 2007 | 11:42 AM
electron_si's Avatar
its gotta be a bad ground. i had a loose bracket on my chassis to tranny ground and my car refused to start. but it would push start. CHECK ALL YOUR GROUNDS
Old Jun 21, 2007 | 11:43 AM
Timmyflys's Avatar
Default Re: (electron_si)
just did the swap got a good valve cover ground tranny ground is good ground on the thermostat is good is there suppose to be one on the starter i don't know wat else it could b
Old Jun 22, 2007 | 06:15 PM
i will try to take a picture of mine tomorrow and post it for you
