Tranny Question
Old Jun 19, 2007 | 06:30 PM
97Integra's Avatar
Default Tranny Question
I have a 1996 del sol s and my tranny is starting to whine so i am going to replace the pressure plate, disc and I will also replace the release bearing and pilot bearing because it comes in the kit.
In the process I would also like to replace my rear main seal, input shaft bearing and seal, throwout bearing and axle seals. My problem is i don't have the part number and don't know where to find the part number for the axle seals. So if anyone could help me with that i would really aprreciate it. I would also like to verify that the parts i am ordering are the correct parts, so please help me. Any info would be greatly appreciated and if you think there are other parts i should look into replacing please let me know. Thanks in advance
So please correct me if i am wrong
In this picture i will be ordering the rear main seal which i believe to be #23
P/N# 91214-PLE-003
In this picture i will be ordering the throwout bearing which i believe to be #4
P/N# 22810-PLW-005
Lastly in this picture i will be ordering the input shaft bearing and input shaft seal which i believe to be #9 & 14
P/N# 91216-PL3-005 AND P/N# 91002-PS0-003
Modified by 97Integra at 4:02 PM 6/21/2007
Old Jun 19, 2007 | 07:36 PM
97Integra's Avatar
Default Re: Tranny Question (97Integra)
bump
Old Jun 20, 2007 | 11:34 AM
97Integra's Avatar
TTT
Old Jun 20, 2007 | 11:41 AM
Libertariat's Avatar
Ek Forever y0!
IMO sounds like you have it under control.
Old Jun 21, 2007 | 03:03 PM
97Integra's Avatar
Default Re: Tranny Question (ek forever guy)
TTT
Old Jun 21, 2007 | 05:37 PM
97Integra's Avatar
ANYBODY?
Old Jun 21, 2007 | 06:31 PM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">IMO sounds like you have it under control.
Old Jun 21, 2007 | 08:15 PM
slowcivic2k's Avatar
Default Re: Tranny Question (EG2Driver)
18731 012 1 OIL SEAL (35X62X8) $6.70
hondaautomotiveparts.com del sol s/si 1996 part number 12 mt clutch and transmission housing seal.
Old Jun 21, 2007 | 08:37 PM
dtapia's Avatar
if your getting a while or growel noise when the car is moving or not sounds like a main shaft bearings # 11 and get a pic of the one bearing on the top of the main shaft is pretty common just did my wifes a month ago . simple job.
Old Jun 21, 2007 | 10:50 PM
97Integra's Avatar
Default Re: Tranny Question (dtapia)
I am actually getting a whining noise while the car is in neutral and the sound automatically disappears when i even slightly touch the clutch.
Old Jun 22, 2007 | 04:45 AM
dtapia's Avatar
yup main shaft bearings . see it all the time and now even more so on the rsx.
Old Jun 22, 2007 | 07:24 AM
97Integra's Avatar
Can you guys actually get me a picture or a part number for the main shaft bearing #11? Thanks
Old Jun 22, 2007 | 07:39 AM
you've displayed it in the picture, its number 14 the seal is part 9.
HaCtHKiD90
Jun 20, 2009 11:50 AM
7andaswitchblade
May 18, 2008 10:58 AM
stefanne3
Nov 1, 2007 06:45 AM
Xemu
12
Jun 27, 2007 11:01 PM
