accord suddenly stalling
Old Jun 19, 2007 | 05:57 PM
stevescivic's Avatar
Default accord suddenly stalling
So my friend's 92 Accord (2.2 Liter engine) drives fine and out of no where the car just dies. It happens most often when its wet outside and today he even developed a weird starter problem.
When he was at the gas station he would turn the key and all he would here is a whole bunch of clicks and then nothing (starter wouldn't actually turn over) and then after a few minutes of "rest time" he'll turn the key again and the darned thing would turn over and run.
I think his clicking issue and not turning over is likely a starter but I can't figure out why his car would just die on the highway when its wet out.
Can someone provide some tips?
Thanks
Old Jun 19, 2007 | 06:49 PM
Default Re: (Evil Monkey)
I forgot to mention that in my first post. Yes I have told him to fiddle with the ignition switch and no it does not stall even when we tap it really hard with our fingers.
Old Jun 19, 2007 | 11:26 PM
JonJon[StreetStars]'s Avatar
Default Re: (stevescivic)
mayb a new battery... even though its green
Old Jun 22, 2007 | 12:25 AM
buddytech's Avatar
Default Re: accord suddenly stalling (stevescivic)
it could be that your battery is bad.. check also the spark plugs, clutch, fuel pump or ignition problem. better check all your honda accord parts and give us an update of what other things did you notice. good luck
Old Jun 22, 2007 | 06:40 AM
DoC-JoneS's Avatar
Default Re: accord suddenly stalling (buddytech)
check to see if the gasket on the dizzy is still in good shape. if moisture gets in the distributor that could do it.
r_u_live
Honda Accord (2013 - 2015)
26
Aug 13, 2018 07:14 PM
acidburn2k2
Mar 10, 2017 08:58 PM
1337knub
Feb 10, 2014 06:57 AM
LS1SSM6
Aug 25, 2011 05:51 AM
leper messiah
Aug 30, 2008 12:27 AM
