help with motor position (leaning)
Well my friends 91 integra was converted to manual and his motor sits crooked. Is it possible that they used the automatic mounts and thats why it sits this way? We want to make sure what the problem is before we order...
Also does anyone have a pic comparing the auto mount to manual mount... thanks
yes you need a different mount just like stated in your earlier post
https://honda-tech.com/zerothread?id=1969522
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy »</TD></TR><TR><TD CLASS="quote">yes you need a different mount just like stated in your earlier post
https://honda-tech.com/zerothread?id=1969522</TD></TR></TABLE>
Wow h-t police..we asked for a pic and confirmation...I'm glad you know how to use the search button noob
best way to fix that problem is buy the auto to 5 speed mount from innovative. cuz who ever did that swap shimmed the mount to work thats why the engine is tilted. i had to run mine like this untill my mount arrived.
buy a mount kit i wil lguarantee to slove the problem. http://www.innovativemounts.com
hit up camp1320.com they got one ofthe best pricing
they used the manual mount, you need to have the manual mount shimed one inch, ive done that and it works fine, i suggest using grade 8 nuts that have a bigger ID the the bolt and that are a inch thick as spacers and get 3 bolts that a an inch longer. ill try and get you some pics of this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmEHboy »</TD></TR><TR><TD CLASS="quote">
Wow h-t police..we asked for a pic and confirmation...I'm glad you know how to use the search button noob</TD></TR></TABLE>
Im glad you dont know how.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">they used the manual mount, you need to have the manual mount shimed one inch, ive done that and it works fine, i suggest using grade 8 nuts that have a bigger ID the the bolt and that are a inch thick as spacers and get 3 bolts that a an inch longer. ill try and get you some pics of this.</TD></TR></TABLE>
sounds good..thanks
and for you
Im glad you dont know how. </TD></TR></TABLE>
your an idiot
sounds good..thanks
and for you
your an idiot
sounds good..thanks
and for you
your an idiot </TD></TR></TABLE>
LMFAOOOOOO!!!
sounds good..thanks
and for you
LMFAOOOOOO!!!
