"Flatness" of Moroso oil pan
Hi all,
I just picked up a Moroso pan and I noticed that it's not very flat. When I lay it on it's flange it rocks a bit on the diagonal. When I performed the same test on a spare GSR pan, it's completely flat, no rocking. I'm hoping that when I tighen all the nut and bolts, the pan will flatten out. Did anyone notice if their pan was flat or not?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satitus »</TD></TR><TR><TD CLASS="quote">Did you get the moroso oil plan flattener?
call up moroso or whereever you bought it and ask for a replacement.
</TD></TR></TABLE>????????
I noticed in your build thread that you also used a Moroso pan. If you haven't already mounted it, can you flip it over and see if it rocks? I have about a 0.1" maximum deflection from flat.
