h22 hesitation, sputter.
Old Jun 19, 2007 | 12:27 PM
chadnixon's Avatar
Default h22 hesitation, sputter.
My car has been acting up on my the last two days. It starts, and idles fine. However, when you put a load on it, like going up a hill or somthing and the RPM's start to climb it has a slight hesitation and studder. It will also do it when your at high RPM's and then let off and let the engine slow the car down. It's worked fine until this point, and the only thing I can think of is I cleaned my air filter (K&n) and reinstalled it. Sence then it's been causing me problems. I only let the filter dry in the sun for about 45 minutes, is it possiable there was a bit of water still remaining which is now in my engine, and if so shouldn't it of cleared it's self up by now? Theres no codes being thrown, and no CEL light on the dash. I've checked over my ingnition wires, plugs, coil, etc to make sure there was no issues there. Do you think that filter was the problem? And if so how do I correct it?
When your driving and you stomp on it it feels like someone is pulling the e-break on and it's got no power at all.
Modified by chadnixon at 1:50 PM 6/19/2007
Que^onda
Honda CR-V & Element
15
Dec 17, 2012 05:30 PM
TeamRiskEG6
Apr 19, 2006 11:30 AM
Jorsher
Feb 23, 2006 09:27 PM
Juccord
Jun 18, 2005 02:50 PM
VTECdTypS
10
Dec 6, 2003 08:37 AM
